Populate Fields By Location Using a Geofence?
2340
5
10-19-2018 08:52 AM
DanielYaw_Jr__GISP
If I have polygons containing data, if point is placed within that polygon on Survey123, I would like to use attributes from that polygon to populate Survey123 fields.
Is this possible???
JamesTedrick
Esri Esteemed Contributor
Hi Daniel,
This is possible through a beta feature - the creation of a custom function.  This is documented in the Early Adopter Community, and includes a point-in-poly data lookup example.  Please see Welcome to our Feedback Community  for more information.
DanielYaw_Jr__GISP
Hi James,
Awesome! Can you please point me to that? I was looking and could not find it...
Dan
Sent from my iPhone
JamesTedrick
Hi Daniel,
The documentation topic is 'Custom pulldata() JS Functions'  The sample zip file at the bottom contains a point in poly look up
DanielYaw_Jr__GISP
Got it, that’s perfect!
Sent from my iPhone
SMauri
Hi Daniel,
maybe you can also create a Custom Pop-up (Crafting custom attribute displays in pop-ups) for your geometry in your WebMap, where you can insert a custom URL (https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche... ) that can invoke Survey123 App with pre-populate questions with value from fields from your polygon.
Something like this:
arcgis-survey123://?itemID=yourAppID&field:QuestionSurvey={FiledNameFromPolygon}
Cheers
Stefano
