Feature Layer Template Gallery doesn't work
1885
10-18-2018 05:01 AM
Nezahat_DenizArgıtlı
When i added a feature layer from template gallery  at Portal for Arcgis( Enterprise 10.6) i get that error message.
"Error getting result parameter"
JeffreySutherland
Hi Nezahat,
Can we get a little more information from you?
  1. What operating system is your Portal installed on?
  2. What language is your Portal set to?
    • It looks like Turkish, but I want to double-check.
  3. What is the exact workflow you are following?
    • Are you on the Content page and clicking Create > Feature Layer > From Template?
  4. Which feature layer template are you trying to create?
    • Is it the Field Interviews template?
    • Are you able to create a feature layer from any feature layer template?
Thanks!
Jeff
Hi Jeff,
First of all, thanks for your attention.
1.Windows Server 2012
2. Yes  it's Turkish , i set it English and then the error message is;
Error
Create Service error: Failed to create the service 'Hosted/hhh.FeatureServer'. Database error has occurred.
3. Yes exactly.
4.I tried most of them , i got the same error.
Thans,
Deniz.
JeffreySutherland
Thanks for the info Deniz!
Was this Portal upgraded for a previous version? As an admin can you check the following:
1. Log in to the Portal Admin API at the following endpoint https://machinename.domain.com/webadaptorname/portaladmin/system/indexer
2. Click Index Status and wait for the page results to load. Once a page loads, you will see a report similar to the following:
4. If some of the results are highlighted in red, your Portal may need to be re-indexed. Navigate back to the following endpoint https://machinename.domain.com/webadaptorname/portaladmin/system/indexer. Click Reindex, in the Mode drop-down select Full. Click the Reindex button and wait.
5. After the Reindex is complete. Check the Index Status (Step 2) again. If none of the results are highlighted in red, open up your Portal and attempt to create a Feature Layer from a Template.
Let me know if this works.
Jeff
Hi Jeffrey,
           The version of the Portal that s in use   is 10.6.1 and we also upgrade it from 10.5.
  • I followed the way you show, i got the index error.
index error
  • Then re-index ,
index completed
  • I created a Feature Layer but the same error
  •  In data store of portal there are some turkish named hosted services . Could this be cousing the error?
