Labels missing in Print output
3978
8
10-17-2018 06:27 PM
UjjwalNigam
Labels show on the map without issuesHi,
I am trying to print secured services and it works fine for most of the part except that the labeling info does not show on the print output.
While I am preparing the map, the labels do appear, but do not show up on print output.
I am using ESRI JS API v3.25.
var labelJson = {
"labelExpressionInfo": { "expression": "" },
"useCodedValues": false,
"labelPlacement": ""
labelJson.labelExpressionInfo.expression = "CONCATENATE([$feature.NAME, $feature.CLASS], ' / ')";
labelJson.labelPlacement = "above-right";
var labelSymbol = new textSymbol();
var lblClass = new labelClass(labelJson);
lblClass.symbol = labelSymbol;
printFeatLyrEquipment.setLabelingInfo([lblClass]); //this is a Feature layer
map.addLayer(printFeatLyrEquipment);
Not sure why is it not printing the labels...any clues?
Thanks in advance!
~UJ
Tags (3)
UjjwalNigam
Okay...so feature layers don't seem to support labels while printing.
I turned on the relevant layers from the dynamic service using setVisibleLayers() and apply definition query/label expression using setDefinitionExpression()setDynamicLayerInfos() respectively - and the labels appear beautifully in the print output!!!
Regards
UJ
UjjwalNigam
Regards
UJ
ReaganSenoron
Is it possible to post your solution here? We have the same problem. We are using FeatureLayer and labels are missing when exported as pdf/image. Thanks
UjjwalNigam
Hello Reagan,
I cannot post the entire solution, but the main snippets on labeling are shown below.
I Hope it helps.
PS: I replied to your email but the mail bounced back.
Regards
Ujjwal
if (readyToPrint) {
                    $.when(ExportMapOverview()).done(function () {
                        $.when(AddPrintLayers(selectedPrintTemplate)).done(function () {
                            showProgressBar();
                            $.when(OverlayMapGrid()).done(function () {
                                setTimeout(TriggerPrintJob3000); //otherwise labels don't make it to the output!
                            readyToPrint = false;
function PrepareLabellingInfo(lblFields) {
    if (lblFields.indexOf(",") > 0) {
        labelAttr = "CONCATENATE([";
        $.each(lblFields.split(","), function (indx, val) {
            labelAttr += "$feature." + val.trim() + ",";
        labelAttr = labelAttr.slice(0, labelAttr.lastIndexOf(","));
        labelAttr += "],',')"//separator is ','
    else
        labelAttr = "$feature." + lblFields;
function TriggerPrintJob() {
    var printTemplateObj, printParams, printTaskObj;
    printTaskObj = new printTask(printGPTaskUrl + "?token=" + token);
    printTemplateObj = new printTemplate();
    printParams = new printParameters();
    printTemplateObj.exportOptions = {
        width: pageWidth,
        height: pageHeight,
        dpi: pageDpi
    printTemplateObj.format = "PNG32";
    printTemplateObj.layout = "MAP_ONLY";
    printParams.map = map;
    printParams.template = printTemplateObj;
    var Web_Map_as_JSON = printTaskObj._getPrintDefinition(map, printParams);
    delete Web_Map_as_JSON.operationalLayers[0].token;
    //add export options
    var expOptions = ', "exportOptions":{"outputSize":[' + pageWidth + ',' + pageHeight + '],"dpi":' + pageDpi + '}';
    var strWebMapJson = JSON.stringify(Web_Map_as_JSON);
    Web_Map_as_JSON = strWebMapJson.slice(0, strWebMapJson.lastIndexOf('}')) + expOptions + '}';
    var payLoad = {
        "Web_Map_as_JSON"Web_Map_as_JSON,
        "Format""PNG32",
        "Layout_Template""MAP_ONLY",
        "f""json"
    //call execute endpoint via XHR
    $.ajax({
        type: "POST",
        url: printGPTaskUrl + "?token=" + token,
        data: payLoad,
        success: printSuccess
    function printSuccess(result) {
        var resultJson = JSON.parse(result);
        if (resultJson.error == null) {//success
            printImgSrc = resultJson.results[0].value.url;
            var printPageElements = '{' +
                                    '"templateName" : "' + selectedPrintTemplate + '",' +
                                    '"imageSource" : "' + printImgSrc + '",' +
                                    '"overviewImageSource" : "' + overviewImgSrc + '",' +
                                    '"mapExtents" : "' + map.extent.xmin + ';' + map.extent.ymin + ';' + map.extent.xmax + ';' + map.extent.ymax + '",' +
                                    '"mapScale" : "' + map.getScale() + '",' +
                                    '"remarks" : "' + document.getElementById("txtRemarks").value + '"' +
            localStorage.setItem("printPageElements", printPageElements);
            ShowPrintOutput();
            $.when(RemovePrintLayers(selectedPrintTemplate)).done(function () {
                hideProgressBar();
        else {
            alert("Error generating print!\nPlease contact administrator.");
            console.log("Error generating print - " + resultJson.error.message);
                hideProgressBar();
Noah-Sager
Just to chime in here, there are a couple of caveats about printing labels with FeatureLayers:
  • Labels currently cannot be printed as part of a FeatureLayer with ArcGIS Server 10.5.1 or any Printing Service published with ArcMap.
PrintTask | API Reference | ArcGIS API for JavaScript 4.9
  • Currently the labelsVisible property must be explicitly set to true for labels to be printed.
FeatureLayer | API Reference | ArcGIS API for JavaScript 4.9
-Noah
RubyStroschein
So if I understand well with 4.9 API it is not possible to print FeatureLayer labels but with older 3.xx this is possible?
I have same problem and I'm using 4.9 js API.
Noah-Sager
This should work fine at 4.9. I am pretty sure that printing labels has been supported since labeling was introduced to 2D MapViews at version 4.8. What sort of issue are you seeing?
RubyStroschein
We now use view.takeScreenshot() but labels added to view as labelClass didn't show on result image of PrintTask
var labelClass = {
// autocasts as new LabelClass()
symbol: {
type: "text", // autocasts as new TextSymbol()
color: "white",
haloColor: "black",
labelPlacement: "above-center",
labelExpressionInfo: {
expression: "Round($feature.CALCACRES,2)"
cluLayer = new w.FeatureLayer({url: url,
labelingInfo: [labelClass],
renderer: renderer
map.add(cluLayer);
Noah-Sager
I think in this case the labelsVisible property must be explicitly set to true for labels to be printed.
