FeatureLayer refreshInterval is broken in 4.9
2477
10-17-2018 05:42 AM
MarkusÅfelt
Noticed that FeatureLayer refreshInterval() -method is broken with ArcgisJS 4.9. With older ArcgisJS 4.8 refreshInterval() is working.
Also noticed that FeatureLayer refresh() -method does not work in ArcgisJS 4.9.
Hopefully this will be fixed in next release.
UPDATE:
attached samples, you need to check your developer tools --> network -table that queries are happening in 4.8 but not in 4.9.
ReneRubalcava
Esri Frequent Contributor
This should be fixed in 4.10, sorry about that.
Thanks!
RobertScheitlin__GISP
Markus,
   Have you called esri tech support to report this and provided a simple sample that reproduces the issue you are seeing?
MarkusÅfelt
I have not called tech support yet but I will try to make sample how to reproduce the issue.
ReneRubalcava
Thanks!
MatthewLewis3
Hi Rene, Is there a formal 100% confirmation that this will be back in 4.10? Can you deliver a patch?  We have number of projects that were relying on this feature as it used near realtime data pushed into feature services.
Not replacing this feature could require a rewrite back to 3.x which id like to avoid.
Matt
