Populate Current Date into Field in Smart Editor Widget
3968
5
10-12-2018 12:05 PM
CarverCounty
Hello all,
I am looking to auto populate a date field with the current date whenever I add a new feature using the Smart Editor widget.   I am aware of the tracking fields but I need to follow a specific field schema and populate a specific field.  I have tried using preset values in the Smart Editor app but cannot figure out how to set it up to handle using the current date.
I am using WAB Dev 2.9.
Thanks in advance,
Craig
CarverCounty
I found this link for the Edit widget but couldn't get the logic written correctly for the Smart Editor.
https://community.esri.com/thread/170004
RobertScheitlin__GISP
Craig,
  I have not tested this at all but this should work. Make these changes to the widget.js _postChanges function:
      // posts the currentFeature's changes
      _postChanges: function (feature) {
        var deferred = new Deferred();
        var result = this._changed_feature(feature, false);
        var returnFeature = result[0];
        var layerId = result[1];
        var type = result[2];
        var layer = null;
        var postDef = null;
        if (returnFeature === null) {
          deferred.resolve("success");
        else if (type === "Add") {
          if (this._traversal.length > 1) {
            this.addNewRelatedRecord = true;
          //Get layer or table info as now user can update related records/features
          layer = this._jimuLayerInfos.getLayerOrTableInfoById(layerId).layerObject;
//Add the autopopulate field value
          if(returnFeature.attributes.hasOwnProperty('Begin_Date_Occ')){
            returnFeature.attributes.Begin_Date_Occ = new Date(Date.now());
          this.attributeInspector.refresh();
//End Add
          postDef = layer.applyEdits([returnFeature], null, null);
          this.addDeferred(postDef, returnFeature, layer, deferred);
CraigPrisland2
Thanks again with the assistance Robert.  I really appreciate it.  After I used your custom code, I added a new point and I am looking for the "Update Date" to auto populate with the current date, is this possible?  It remains empty.
However, after I saved this new point, in the Dev console I get the following error saying that this.attributeInspector is undefined.
Again, thanks for all you do!
Craig
Craig,
   Change that line to:
this.attrInspector.refresh();
CraigPrisland2
Hi Robert,
Thanks for the reply.  However, after updating this line, I am now getting the following error when trying to save this new point.  I did ensure that the field ("UPDATEDATE") that I am trying to auto populate is a Date field.  Also, my web console is not returning any errors as well?
Craig
