Selecting multiple features with graphics
3144
8
10-11-2018 08:27 AM
ajd018
I am trying to select multiple polygon features and have a graphic drawn on top of the features to show selection with this code. Right now, the selection works and selects the features (I know this because it shows as selected in the featuretable). But the graphic only draws over a single feature. Is there a way to have it draw over multiple features?
var selectionToolbar;
map.on("load", initSelectToolbar);
var selectline = new SimpleLineSymbol();
selectline.setWidth(4);
selectline.setColor(new Color([0,255,255, 1]));
var selectlineSymbol = new SimpleFillSymbol();
selectlineSymbol.setOutline(selectline);
selectlineSymbol.setColor(new Color([46,191,240, 0]));
on(dom.byId("selectFieldsButton"), "click", function () {
selectionToolbar.activate(Draw.EXTENT);
on(dom.byId("clearSelectionButton"), "click", function () {
featurelayername.clearSelection();
map.graphics.clear();
function initSelectToolbar (event) {
selectionToolbar = new Draw(event.map);
var selectQuery = new Query();
on(selectionToolbar, "DrawEnd", function (geometry) {
selectionToolbar.deactivate();
selectQuery.geometry = geometry;
selectQuery.returnGeometry = true;
selectQuery.where = "1=1";
featurelayername.queryFeatures(selectQuery, function (featureSet) {
featurelayername.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW);
var Geom = featureSet.features[0].geometry;
var gra = new Graphic(Geom, selectlineSymbol);
map.graphics.add(gra);
KenBuja
MVP Esteemed Contributor
You're only creating a new graphic from the first feature in the featureset with this line.
You'll want to loop through the featureset and do that to each feature.
array.forEach(featureSet, function (feature) {
  Geom = feature.geometry;
KenBuja
ajd018
I incorporated this way. Cant get the graphics to show up.
   var Geom = feature.geometry;
KenBuja
Are you seeing any messages in the console?
ajd018
init.js:89 g {message: "Timeout exceeded", response: {…}, status: undefined, responseText: undefined, xhr: XMLHttpRequest, …}
also:
Active resource loading counts reached to a per-frame limit while the tab is in background. Network requests will be delayed until a previous loading finishes, or the tab is foregrounded. See <URL> for more details
KenBuja
Did you add the module for array?
require([...,"dojo/_base/array",...], function(...,array,...){
ajd018
JobStatusLyr.clearSelection();
JobStatusLyr.queryFeatures(selectQuery, function (featureSet) {
JobStatusLyr.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW);
JohnGrayson
Esri Alum
Q: Is featureSet a FeatureSet or an array of Graphic objects?  If its a FeatureSet, then try looping over the 'features' property which is an array of Graphic objects:
array.forEach(featureSet.features, function (feature) {
ajd018
That did it. Great thanks.
