Sorted arcpy.da.SearchCursor (sort of)
2044
7
10-09-2018 10:34 AM
JamesCrandall
I just can't stand Stackexchange so asking some familiar folks around here for some assistance with rearranging a dictionary that I'm building from an arcpy.da.SearchCursor.  Not really arcpy-specific that I need help with -- what I need is to take this dictionary:
  "junctionMatrix": [
      "WCU": "STA1E_CELL_7",
      "juncA": "S-1A",
      "juncB": "S-1B",
      "juncDistance": 5475.69
      "juncA": "S-1B",
      "juncB": "S-1A",
      "juncA": "S-1A",
      "juncB": "S-1C",
      "juncDistance": 8140.32
      "juncA": "S-1C",
      "juncB": "S-1A",
      "juncA": "S-1B",
      "juncB": "S-1C",
      "juncDistance": 6891.71
      "juncA": "S-1C",
      "juncB": "S-1B",
...and rearrange so that values are sorted in this manner:
  "junctionMatrix": [
      "juncA": "S-1A",
      "juncB": "S-1B",
      "juncA": "S-1A",
      "juncB": "S-1C",
      "juncA": "S-1B",
      "juncB": "S-1A",
      "juncA": "S-1B",
      "juncB": "S-1C",
      "juncA": "S-1C",
      "juncB": "S-1A",
      "juncA": "S-1C",
      "juncB": "S-1B",
Any suggestions are appreciated!
JoshuaBixby
MVP Esteemed Contributor
Try:
d = {
...   "junctionMatrix": [
...       "WCU": "STA1E_CELL_7",
...       "juncA": "S-1A",
...       "juncB": "S-1B",
...       "juncDistance": 5475.69
...       "juncA": "S-1B",
...       "juncB": "S-1A",
...       "juncB": "S-1C",
...       "juncDistance": 8140.32
...       "juncA": "S-1C",
...       "juncDistance": 6891.71
>>> d["junctionMatrix"] = sorted(d["junctionMatrix"],
...                              key=lambda x: (x['juncA'],x['juncB']))
JoshuaBixby
Just so I understand, your want a double sort using juncA, juncB?
JamesCrandall
Yes, in the manner of the second output example above!
JoshuaBixby
Try:
d = {
JamesCrandall
Yep!  Thank you!
JamesCrandall
The closest I've gotten is to take the data = {} that is populated from my SearchCursor and reset it with:
data = sorted(data["junctionMatrix"], key=lambda x: (x["juncA"], x["juncB"]))
JoshuaBixby
I see I suggested what you already tried.  In terms of sorting, the syntax we both used works, so I am confused what isn't working for you.
JamesCrandall
I was close, you nailed the complete solution --- I was not correctly setting the "data" variable and get it under the "junctionMatrix" attribute.  Pretty simple misunderstanding on my part!
Thanks again.
