Create a hyperlink to a feature
2921
5
10-04-2018 02:55 PM
MikeFiguray
I was wondering if there is a way to create a hyperlink to a specific feature in a web map which I could then paste into an email? I have users that occasionally forget to finish editing a feature and it would be great to link to the ObjectID or something and have it bring them right to the feature to complete editing.
Thank you!
Mike
KellyGerrow
Esri Alum
Hi Mike,
I think if you set up a feature layer search in the web map, you can use URL parameters just as Xander Bakker‌ mentioned. Depending on the app that your users are using, you can also use search URL parameters within apps:
Use URL parameters to modify embedded maps—ArcGIS Online Help | ArcGIS
Using URL Parameters In Web Apps
Use URL parameters—Web AppBuilder for ArcGIS | ArcGIS
Please let us know if any of this gets you up and running.
Kelly
DouglasCochran
You can Share a Scene via URL in Scene Viewer.  Will that work for you?
MikeFiguray
I've never worked with Scenes, but it looks like I can only share the whole scene, and not an individual feature.
XanderBakker
Esri Esteemed Contributor
Have a look at this link: Use URL parameters to modify maps—ArcGIS Online Help | ArcGIS , at the end you will find the topic "Find location or feature to open".
KellyGerrow
Esri Alum
Hi Mike,
Kelly
MikeFiguray
Xander and Kelly, Thank you very much! That looks like it should do it!
Mike
