arcpy: get access to layer that's in group layer?
6546
15
09-21-2018 08:16 AM
helenchu
Hi
I created a model builder and scripted it out to python.  My issue is it only works if the layer is outside of group layer.  How can I modify it to works in both inside and outside of group layer?  Thank you very much for your help.
import arcpy,sys, os
arcpy.env.workspace = r"C:\GIS\MyGeodatabase.gdb"
mxd = arcpy.mapping.MapDocument("CURRENT")
layerName = 'street'
lyr = arcpy.mapping.ListLayers(mxd, layerName)[0]
fc = arcpy.GetParameterAsText(0)
Street = "Street"
selCount = 0
if lyr.getSelectionSet(): # If there are selected features
selCount = len(lyr.getSelectionSet())
arcpy.AddMessage("{0} has {1} features selected.".format(fc, selCount))
try:
# Process: Copy Features
arcpy.CopyFeatures_management(Street , street_CopySelected, "", "0", "0", "0")
JoshuaBixby
MVP Esteemed Contributor
Saying something "doesn't work" often isn't specific enough for people to offer much feedback.  Does it generate an error when run within a group layer?  If so, what is the error, including the trace back.  Or, does it give unexpected results?  If so, what are you expecting and what are you seeing?
helenchu
It just doesn't find that layerName so the script did nothing.  Thanks.
JoshuaBixby
When the layer is nested under a group layer, what does the following code give for results:
for lyr in arcpy.mapping.ListLayers(mxd):
    print lyr.longName
helenchu
TopLayerGroup\Street
I replaced Street = lyr.longName and it still does not work.  It gives my the selection count but not doing the copy features.  Thanks.
My code looks like this:
df = arcpy.mapping.ListDataFrames(mxd)[0]
for lyr in arcpy.mapping.ListLayers(mxd,"",df): #loop layers
if lyr.name == "Street":
Street= lyr.longName
selCount = 0
arcpy.AddMessage("{1} features selected.".format(fc, selCount))
try:
arcpy.CopyFeatures_management(lyr.Street, street_CopySelected, "", "0", "0", "0")
del df
except Exception as e:
print e.args[0]
RandyBurton
Can you post a screenshot of how your layers are organized?
Also, it helps to see formatted code: Code Formatting... the basics++
helenchu
helenchu
# Import arcpy module
arcpy.env.workspace = r"C:\GIS\MyGeodatabase.mdb"
layerName = 'Street'
Street = "Street"
street_CopySelected = "street_CopySelected"
            arcpy.AddMessage("name: " + lyr.longName)
            layerName = lyr.longName
            try:
                arcpy.CopyFeatures_management(Street, street_CopySelected, "", "0", "0", "0")
                del df
                print e.args[0]
RandyBurton
Thanks for formatting.  It helps to see the indentation.
Regarding line 23:
If lyr.getSelectionSet() == None, then len will return an error.  You might want to check first:
    # do other things with the layer selection‍
Since you are using MapDocument("CURRENT"), are you planning to only use the tool inside ArcMap?
JoshuaBixby
Python is case sensitive, i.e., "Street" != "street".  In your original code, you are using both.  Trying being consistent with your case.
