arcpy: get access to layer that's in group layer?
8244
15
09-21-2018 08:16 AM
helenchu
Hi
I created a model builder and scripted it out to python.  My issue is it only works if the layer is outside of group layer.  How can I modify it to works in both inside and outside of group layer?  Thank you very much for your help.
import arcpy,sys, os
arcpy.env.workspace = r"C:\GIS\MyGeodatabase.gdb"
mxd = arcpy.mapping.MapDocument("CURRENT")
layerName = 'street'
lyr = arcpy.mapping.ListLayers(mxd, layerName)[0]
fc = arcpy.GetParameterAsText(0)
Street = "Street"
selCount = 0
if lyr.getSelectionSet(): # If there are selected features
selCount = len(lyr.getSelectionSet())
arcpy.AddMessage("{0} has {1} features selected.".format(fc, selCount))
try:
# Process: Copy Features
arcpy.CopyFeatures_management(Street , street_CopySelected, "", "0", "0", "0")
helenchu
Thanks for the tip!  When I drag my Street layer out of TopLayerGroup, the codes work just fine.  I begin to suspect if group layer is supported by ESRI for doing most of data management tools?
RandyBurton
You may have some issues with how you are using getSelectionSet.  My test code:
for l in lyr:
    print l.name, l.getSelectionSet(), len(l.getSelectionSet()) if l.getSelectionSet() is not None else 'None'
    #  and if you only want to work with layer named 'street'
    if l.name == 'street':
        # do something‍‍‍‍‍‍‍‍‍‍‍
RandyBurton
You might try something like:
for lyr in arcpy.mapping.ListLayers(mxd, layerName)[0]:
        arcpy.AddMessage("{} has {} features selected".format(lyr.name, len(lyr.getSelectionSet()))
helenchu
Randy,
I tried your codes and they did not work for me.   Thanks.
Error:
File "C:\Working\Python\python_script\copy_test_1.py", line 9, in <module>
File "c:\program files (x86)\arcgis\desktop10.6\arcpy\arcpy\arcobjects\mixins.py", line 401, in __iter__
self.layers
AttributeError: LayerObject: Get attribute layers does not exist
RandyBurton
Try this change:
layerName = 'Street'
for lyr in arcpy.mapping.ListLayers(mxd, layerName): # remove [0]
helenchu
I called ESRI support and the solution is
arcpy.CopyFeatures_management(lyr, street_CopySelected, "", "0", "0", "0")
It can not read the longName but it could read the object lyr.
Thank you all so much for your help.
