Make layer from selection not working
15708
11
09-18-2018 08:25 AM
HeatherScroggins
I'm working in Pro (version 2.2.2) trying to create a selection layer. I've tried both right clicking on the layer and going to 'Make layer from selected features' and going to the Data tab and clicking the 'Layer from Selection' button, but nothing seems to happen.
Has anyone else experienced this and discovered what was wrong?
LaurenLumHee
Moving the layers into a new project will remedy the issues. I reached out to technical support and that was the resolution we found.
MichaelVolz
Esteemed Contributor
What is the datasource of your data (e.g. file gdb, SDE, other)?
What type of features are you working with (e.g. points, lines, or polygons)?
HeatherScroggins
The data is from an SDE enterprise geodatabase (10.2) on SQL Server (2012). I am working off a version.
The data itself is a line feature class.
MichaelVolz
It worked for me from a file gdb, but not from an Oracle SDE database.  I wonder if there is a permissions issue with SDE in relation to this feature, but I receive no error message just nothing occurs with SDE.
HeatherScroggins
I just tried making a selection layer off a line feature class from a file geodatabase and that did not work for me. I guess it could be a permissions thing, but creating selection layers in ArcMap works fine, I would think that if it was a permissions thing, ArcMap wouldn't allow it either.
And yeah, no error message for me either.
KoryKramer
Esri Esteemed Contributor
Hi Heather and Michael.  I just checked in file gdb and SQL server and Make Layer from Selected Features works.
This would probably be a good candidate to work on with technical support.  Esri Support Home
HeatherScroggins
Thanks Kory. I'm going to have my coworker test it out next time she is in Pro just to make sure that it isn't a setting on my computer and if it fails for her as well, I'll escalate it to technical support.
MichaelVolz
Kory:
Could this be an Oracle SDE specific issue?  It works for you in SQL Server, but it does not work for several people at my org using an Oracle SDE database.
KoryKramer
I suppose it could be but it would need to be investigated.  I searched support cases and don't see this as a known issue.
LaurenLumHee
