ESRI Search Widget activeSourceIndex Usage
1630
09-15-2018 01:23 PM
NoahHuntington2
I am looking for some example of setting the default search service to all(feature layer and esri geocoding).  but I also care about the order of the results returned.
I suspect this is accomplished using the activeSource parameter of the search widget. But have not been able to find an example of this implemented.
I have tried implementing like this..
var searchWidget = new Search({    container: "searchDiv",    view: view,    allPlaceholder: "Places or Tyler Communities",    activeSource: 0,    sources: [{        featureLayer: {            url: "https://services5.arcgis.com/6gTxIFMxZdWxCrVQ/arcgis/rest/services/...",            popupTemplate: { // autocasts as new PopupTemplate()                title: "{customer} is  Tyler Connected Community!",                overwriteActions: true            }        },        activeSourceIndex: 1,        searchFields: ["customer", "city", "state"],        displayField: "customer",        exactMatch: false,        outFields: ["*"],        name: "Tyler Communities",        placeholder: "example: city of birmingham",        zoomScale: 500000    }]});
and also like this...
searchWidget.activeSource = 0;
But both return this error...
dojo.js:340 Uncaught TypeError: [accessor] cannot assign to read-only property 'activeSource' of esri.widgets.Search.SearchViewModel
Any help is greatly appreciated.
RobertScheitlin__GISP
Noah,
   As you can see from your error the activeSource property is readonly
activeSourceFeatureLayer|Locatorreadonly
what you need to use is activeSourceIndex which will let you set the number/index of the source.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html#activeSourceI...
NoahHuntington2
Hi Robert. Thank you for the response.  Good to know I was getting close.  I still have not seen activeSourceIndex implemented.  Can you provide an example?
Noah,
  I have not seen any example of it being implemented either. It is a simple property that you set either in the constructor or after creating the widget instance, so nothing special to show in code.
