"Cannot Open File for Writing" error msg
1960
09-15-2018 02:48 PM
CarolynChainey-Davis
An error message when trying to run the .exe file for the ArcGIS 1.6.1 download (see also attached screenshot):
"Cannot open file for writing:  cannot open file for writing: D:/Documents/ArcGIS Earth 1.6.1......"
Is ArcGIS earth a free program for ppl that don't have ESRI's ArcGIS?  Is there an online only version?  I need a kmz/kml viewer to open a 1.1GB kml file...
Thanks for listening,
Carolyn
AdrianWelsh
MVP Honored Contributor
Carolyn,
Can you just use Google Earth for viewing the KML file?
Google Earth
unfortunately it is much too big a file. Google earth won't open anything bigger than 200 MB, and this is a 1.1GB File! Huuuge!
AdrianWelsh
Carolyn,
If after Joshua's reply you still cannot get ArcGIS Earth to install properly, it is possible that QGIS or MapInfo could view the large KML file (though I think MapInfo is not open source nor free, so QGIS is really the option here). Someone appeared to have success opening a 500 MB kml file on those platforms: mapinfo - Opening very large kml files in QGIS
JoshuaBixby
MVP Esteemed Contributor
I just downloaded and installed ArcGIS Earth without incident.  I gave Esri a junk-mail e-mail address that has no connection to any of my other accounts with Esri, so Esri's website had no idea I was a customer already.
Typically the error you are seeing happens when the download is corrupted.  It could be the file Esri stored on the server was corrupted, it could be a cached version of the file on Akamai or some other caching service was corrupted, or it could be getting corrupted while downloading through your ISP connection.  I would reboot your machine.  If that doesn't work, try re-syncing your modem.
In terms of whether ArcGIS Earth is "free," the 2017 Product-Specific Terms of Use state:
65.  May only be used in conjunction with other Esri Product(s).  Third-party technologies may also be used in conjunction with ArcGIS Earth as long as ArcGIS Earth is always used in conjunction with other Esri Products.
I would say that statement is sufficiently vague to not limit its use.  At a minimum, just sign up for a free ArcGIS Online account and that would appear to meet their terms.
