When calling queryFeatures on a FeatureTable, not all attributes are loaded
2172
09-11-2018 08:32 AM
KeithLarson1
Hello all,
I am trying to query a FeatureTable in QML, so I pass it QueryParameters with the whereClause I need and it is giving me the correct amount of features. I have checked the fields property of both the table and the queryFeaturesResult and they both have the proper number of fields, which is 60 in this case. However, when I look at the attributes from the result, there are only 13 available.
I have had this problem in the past and was able to fix it, but I can't remember what I did. It is just very confusing that it does this, despite it knowing how many fields there are supposed to be, and that the only input I have is the QueryParameters which has no way of specifying the fields to return. Any help is appreciated.
Keith
LucasDanzinger
Esri Frequent Contributor
It sounds like the Feature objects in the result need to be loaded first before you can access all of its attributes. Are you using an online service (ServiceFeatureTable)? If so, you could try using the queryFeaturesWithFieldsOption - ServiceFeatureTable QML Type | ArcGIS for Developers
With this, you can specify to use the Enums.QueryFeatureFieldsLoadAll enum (Enums.QueryFeatureFields enumeration | ArcGIS for Developers ) to make all features returned fully loaded.
Otherwise, you could also go through the feature iterator and call load() on each. This is a bit more work because you will need to set up a signal handler for loadStatusChanged for each feature.
LucasDanzinger
KeithLarson1
Oh, thanks. I am using tables from a webmap, but they are from a feature service, so I was able to use queryFeaturesWithFieldsOption. Thanks again!
