Problem with Qt SDK 10.2.6
1831
09-03-2018 07:09 PM
NikeNike
I am trying to run the basic widget on my local desktop using the instructions for working with local data from this link:
Add a map to your app—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
The program compiles fine but I get a the following assertion when I try to run it:
<RTC_ASSERTION>
Runtimecore Assertion Failed!
Condition: shader != 0c:\dev_d\daily_win_wpf_rtc_release_748.6.qt\runtimecore\hal\src\shader_program_ogl.cpp(322)
</RTC_ASSERTION>
I guess it's an OpenGL issue so I tried updating my graphics driver to the latest version but it did not solve the problem.
I am using the following:
- Win 10 Pro (10.0.17134)
- Qt Creator 3.4.1
- Qt 5.4.2 MSVC2013 OpenGL (32bit)
- Intel HD Graphics 620
- Shader Version 5.1
- OpenGL 4.5
- Microsoft DirectX 12.0
Due to project requirements, I can only use this SDK as the newer Qt and MSVC is not available to me.
The program output is as follows:
Qt: Untested Windows version 10.0 detected!
PATH SAMPLE: "C:/Program Files (x86)/ArcGIS SDKs/Qt10.2.6/sdk/samples/data\"
Starting server
Local server process started
<RTC_ASSERTION>
</RTC_ASSERTION>
QPainter::begin(): QOpenGLPaintDevice's context needs to be current
QPainter::begin(): Returned false
QPainter::setRenderHint: Painter must be active to set rendering hints
QPainter::worldTransform: Painter not active
QPainter::save: Painter not active
The program has unexpectedly finished.
Any help in the right direction is much appreciated!
Tags (1)
LucasDanzinger
Esri Frequent Contributor
I think the issue might be that you have the OpenGL version of the Qt msvc kit, but with the 10.2.6 release, we only supported ANGLE rendering on Windows. Nowadays, there is just one kit that supports both, but with 5.4.2, there were 2 separate downloads. Could you try downloading the ANGLE kit (the kit that does not specify OpenGL)
LucasDanzinger
