Quick Capture Button Size
1358
09-07-2018 02:24 PM
BrianLomas
I currently have 3 buttons on my quick capture app. I would like those buttons to fill the entire screen instead of just the top 3rd. Does anyone know where in the code I can change this?
Thanks.
ErwinSoekianto
Esri Alum
Brian,
It depends, normally you could use "anchor.fill : parent", but can you show us how the UI looks like and what do you use in the code? To see if we can give you some pointer.
Thank you,
Erwin.
BrianLomas
I am basically working with the default settings of the quick capture template. I haven't changed much. Below is what the current UI looks like.
BrianLomas
I have tried editing the qml code in the featurebutton.qml code, the datacapturepage.qml, and the styledbutton.qml but nothing seems to effect the size of the button.
ErwinSoekianto
Esri Alum
Johnathan Hasthorpe‌, do you have any idea how to change the size of the button?
