Loop through multiple folder and composite-band of raster of Same folder
5704
14
09-07-2018 03:34 PM
BIJOYGAYEN
Hi
I am trying to make a loop function.  loop function picks up the rasters file from every subfolder, composite(layer stack#) the raster file and keeps it in that subfolders. I am getting an error. please help anyone. Under ppp folder have two subfolder P1 and P2 both folders contain the raster file. Thanks in advance.
import arcpy ,os ,sys
from arcpy import env
from arcpy.sa import *
env.workspace = "G:/ANFIS_DATA_2/PRECEPITATION/aug/POINT/ppp"
ws = r"G:/ANFIS_DATA_2/PRECEPITATION/aug/POINT/ppp"
walk = arcpy.da.Walk(ws, topdown=True, datatype="RasterDataset")
for dirpath, dirnames, filenames in walk:
        print "Processing folder:", dirpath
        rasters=[]
        for filename in filenames:
            raster= os.path.join(dirpath,filename)
            print raster
            if filename.endswith(".tif"):
                    rasters.append(raster)
print "-rasters found:",len(rasters)
if len(rasters) != 0:
            print " layerstack"
            file_name_only = os.path.splitext(rasters[0]) [0]
            tifname = file_name_only[-9:]
            print tifname
            ras_name = os.path.join(dirpath,'L_{0}.tif'.format(tifname))
            layr =arcpy.CompositeBands_management(rasters,ras_name)
else :
    print" -skipping folder..."
print "Finished..."
Tags (1)
DanPatterson_Retired
Your indentation is throwing off the loops... try this
    rasters=[]
        print raster
        print " layerstack"
        print tifname
    else:
print "Finished..."
RandyBurton
Can you share the error message?
BIJOYGAYEN
I had a small mistake to fix it. The code just picks up the p2 folder's raster file and composite it, also saves it by first raster file name(of the P2 folder) in the same folder. But The function did not pick up the file from another folder(P1) and no composite is going on.
 Here is two problem
              1.code does not pick up the file from another folder at the same time
              2.composite  file save by first raster file name of the folder
BIJOYGAYEN
But I cannot solves the previous reply problems.
    rasters=[]
        print raster
        print " layerstack"
        print tifname
    else:
print "Finished..."
BIJOYGAYEN
Message File Name Line Position
Traceback
<module> <module1> 36
CompositeBands C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\management.py 13824
ExecuteError: ERROR 999999: Error executing function.
Failed to execute (CompositeBands).
My aim is, the code will go to every sub-folder ( P1, P2,...) under ppp folder after that code picked up the raster files individual folder and will do band composite and saved this composite file by unique name in the same folder(P1,P2,...).
PPP
   P1 -Raster files picked up--- Band composite---save in P1 folder by unique name.
   P2 -Raster files picked up--- Band composite---save in P2 folder by unique name.
   P-Raster files picked up--- Band composite---save in Pfolder by unique name.
show some of the print statements
BIJOYGAYEN
Processing folder: G:/ANFIS_DATA_2/PRECEPITATION/aug/POINT/ppp
-rasters found: 0
-skipping folder...
Processing folder: G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug1_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug22_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug25_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug26_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug27_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug30_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug31_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug6_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug7_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug8_pre.tif
G:\ANFIS_DATA_2\PRECEPITATION\aug\POINT\ppp\p1\aug9_pre.tif
-rasters found: 11
layerstack
\aug1_pre
File "<module1>", line 36, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\management.py", line 13824, in CompositeBands
raise e
print tifname
printing the tifname is not useful...
print the ras_name to make sure that it is correct and make sure 'rasters' in the CompositeBands is correct.
That is where the error message and I suspect that the name is not correct
BIJOYGAYEN
Then How to save this composite file by unique name for different folder???
