Loop through multiple folder and composite-band of raster of Same folder
5970
14
09-07-2018 03:34 PM
BIJOYGAYEN
Hi
I am trying to make a loop function.  loop function picks up the rasters file from every subfolder, composite(layer stack#) the raster file and keeps it in that subfolders. I am getting an error. please help anyone. Under ppp folder have two subfolder P1 and P2 both folders contain the raster file. Thanks in advance.
import arcpy ,os ,sys
from arcpy import env
from arcpy.sa import *
env.workspace = "G:/ANFIS_DATA_2/PRECEPITATION/aug/POINT/ppp"
ws = r"G:/ANFIS_DATA_2/PRECEPITATION/aug/POINT/ppp"
walk = arcpy.da.Walk(ws, topdown=True, datatype="RasterDataset")
for dirpath, dirnames, filenames in walk:
        print "Processing folder:", dirpath
        rasters=[]
        for filename in filenames:
            raster= os.path.join(dirpath,filename)
            print raster
            if filename.endswith(".tif"):
                    rasters.append(raster)
print "-rasters found:",len(rasters)
if len(rasters) != 0:
            print " layerstack"
            file_name_only = os.path.splitext(rasters[0]) [0]
            tifname = file_name_only[-9:]
            print tifname
            ras_name = os.path.join(dirpath,'L_{0}.tif'.format(tifname))
            layr =arcpy.CompositeBands_management(rasters,ras_name)
else :
    print" -skipping folder..."
print "Finished..."
Tags (1)
DanPatterson_Retired
before the composite band rasters call, what is ras_name?
you could add something to make it unique
extra = 0
ras_name = os.path.join(dirpath,'L_{0}.tif'.format(tifname)) + str(extra)
extra += 1
BIJOYGAYEN
ras_name saves root + file name.
I am just adding your code for the unique name but code give me the error
rasters=[]
print raster
print " layerstack"
tifname = file_name_only[-5:]
# print tifname
extra = 0
extra += 1
else:
print "Finished..."
Message File Name Line Position
Traceback
<module> <module1> 37
CompositeBands C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\management.py 13824
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000445: Extension is invalid for the output raster format.
Failed to execute (CompositeBands).
BIJOYGAYEN
Thank you so much. It is working.
I have another question suppose P1, P2.. , folder containing different name file as like idwaugpre.tif file i want to avoid this file picking time. Have any way?
Bijoy  You should mark my answer correct then, so that people that an answer was obtained.
As for your second part, For tasks like this, it is preferable to make a tool in a toolbox and make parameters in your script than enables users to make selections to limit or expand upon the criteria.  It is far easier this way than coding for all possibilities of potential entries.
BIJOYGAYEN
Thank you so much. I solved this issue.
