network location for ArcGIS server directory
4061
8
09-04-2018 05:02 AM
User35489
I am trying to update arcgis server directories from local server drive to network location. It gives me below error. Kindly suggest
Failed to create the folder '\\192.168.0.1\GISRepository\ArcGISServer106\ArcGISServerDir'.
Environment:
ArcGIS Server 10.6 on Windows 2012 R2
Access to above folder is granted to everyone
I can add above location as 'connect folder' from ArcMap from server.
Thanks again
-AS
2 Solutions
JonathanQuinn
Esri Notable Contributor
Try giving the account explicit read/write access through the Share rather than relying on "Everyone". I rarely expect Server to be able to write to a directory because "Everyone" can write to it anymore and typically need to give the ArcGIS Server user explicit permissions.
RandallWilliams
No. The user you log into the portal as is irrelevant. The account that matters is the 'ArcGIS Account', aka the runas account that is used to start the portal service. If you were to log into this machine as the runas account, can you write to this share?
RandallWilliams
Is ArcGIS Server running under a local account or a domain account?
User35489
It's a domain account.
and, Network Storage is on different domain than ArcGIS Server.
JonathanQuinn
User35489
still facing the issue, even after granting 'read/write/full-control' access.
any more suggestions please
JonathanQuinn
Run ProcMon on the Server and filter the path for the share you're trying to use. It may help you determine why it's failing:
Process Monitor - Windows Sysinternals | Microsoft Docs
User35489
I found below info, mostly highlighting access denial.
10:27.8javaw.exe19592CreateFile\\192.168.0.1\GISRepository\ArcGISServer106\ArcGISServerDirACCESS DENIEDDesired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
I want to add below information
Users are managed by portal. I am logged in as admin using Portal named user not a domain user. Will this make difference in access grants ?
RandallWilliams
User35489
Thank you so much, works fine now.
