Update cell values in an existing Excel workbook
4913
08-31-2018 03:19 AM
deleted-user-r12oOPKQjs2J
I need to export data from a feature class attribute table to an existing Excel (.xls) workbook.
The workbook has some formatting, so what I need ideally, is a way to write values in the existing workbook.
Any suggestions on how to do this using Python ?
(Ideally, Python in ArcGIS Pro)
DanPatterson_Retired
There are separate packages that can be used with python that you can install for use with arcmap and ArcGIS Pro
Creating Excel files with Python and XlsxWriter — XlsxWriter Documentation
Python Excel
xlrd · PyPI
You should see if they are installed in your site-packages folder already or you need to do a pip install (arcmap) or if using pro, see whether there is a conda install option
Python Excel
xlrd · PyPI
NeilAyres
