Adding color to building faces?
2418
08-22-2018 08:06 AM
DanielChantlos1
Hi,  I would like to know if it is possible to simply add colors to faces of buildings using RGB values.
I have been using Sketchup to add colors to faces of buildings, but it takes time to convert to a new file format for use in CityEngine. There has to be an easy way of doing this in CityEngine, right?
LR
You'll have to do it with CGA.
color(R,G,B) (range 0-1)
or
color("#RRGGBB") (00-FF)
You can also make an attribute, which lets you pick a color in the inspector:
Define after the CGA version:
@Color
attr myColor="#FF0000"
and then.. color(myColor)
DanielChantlos1
I am very new to CityEngine.
If I had a simple 6 face prism, what would the steps be to apply different colors to each face?
BenLeslie1
Use comp(f) to separate the prism into its component faces and then set each face to a different colour
Prism-->
comp(f){top:Red | bottom:Green | front:Blue | back:Yellow | left:Magenta | right:Cyan}
Red-->color(1,0,0)
Green-->color(0,1,0)
etc....
LR
You can also use the face index, like ... {0: Red | 1: Green | ... I had a face labeling script somewhere but can't find it atm.
