IOS swift - Webmap features access
1723
08-20-2018 08:58 AM
MohamedMuzammil
I have the web map that contains the map service and feature service.
1. I want to get the feature count and feature details based on map extent
2. How to apply filter/search for the features in the webmap
Please provide the example to access from web map. How to read and apply.
Thanks for your support
GarimaDhakal
Hi Mohamed Muzammil‌,
We have the following samples that might help you to get started.
1. Feature layer query
2. Query a map image sublayer
3. Statistical query
Queries are performed on an AGSServiceFeatureTable. If a map is created from a portal item (webmap),  AGSServiceFeatureTable can be retrieved from the map as follows:
  • Get a list of operational layers from a map using the operationalLayers property on an AGSMap and filter those layers using layerId to get the required feature layer and map image layer.
  • AGSFeatureLayer may expose a AGSFeatureTable through a featureTable property. The AGSFeatureTable can be casted to AGSServiceFeatureTable.
  • Sublayers of AGSArcGISMapImageLayer may expose a AGSServiceFeatureTable through a table property.
I hope this helps. Please let me know if you have further questions.
Thank you,
Garima
MohamedMuzammil
Hi Garima,
Thank you for the reply.
I have tried the following but it is not filtered in the map
1. I have added portal item into the map
2. get the list of operational layers (let layers:[AGSLayer]! =  self?.map.operationalLayers as! [AGSLayer])
3. assigned in feature layer (self?.featureLayer1 = layers[3] as! AGSFeatureLayer)
4. applied filter (self.featureLayer5.definitionExpression="field='xxxx'")
5. -------- No filter applied in the map ---------
please guide me how to apply filter and filtered values should be changed in the map.
thanks
GarimaDhakal
Mohamed Muzammil‌ In step 4, you are applying definitionExpression on featureLayer5. Are you trying to apply definition expression on featureLayer1 or featureLayer5?
MohamedMuzammil
thank you for your support. I got the answer with your reply
