Not able to perform Query on FeatureLayer and GeoCode using ESRI's geocode service.
1320
09-02-2018 03:30 AM
RavindraSingh
I am using
  • ArcGIS-Runtime-SDK-iOS', '100.2.1'
  • XCode 9.4.1
  • iOS 11.4 Simulator
I am trying to perform GeoCode
using - https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer
using below Code - (code is copied from ESRI-GitHub Sample Codes )
func testGeoCode(){
        // Try to query MapService
        let locatorURL = "http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
        let locatorTask:AGSLocatorTask = AGSLocatorTask(url: URL(string: locatorURL)!)
        let geocodeParameters:AGSGeocodeParameters = AGSGeocodeParameters()
        geocodeParameters.resultAttributeNames.append(contentsOf: ["*"])
        geocodeParameters.minScore = 75
        //perform geocode with text
        locatorTask.geocode(withSearchText: "California", parameters: geocodeParameters, completion: { (results:[AGSGeocodeResult]?, error:Error?) -> Void in
            if let error = error {
                print("testGeoCode Error::: \(error)")
            else {
                if let results = results , results.count > 0 {
                    print("GeoCode Result found::: \(results.count)")
                    //create a graphic for the first result and add to the graphics overlay
                    _ = AGSGraphic(geometry: results[0].displayLocation!, symbol: nil, attributes: results[0].attributes as [String : AnyObject]?)
                    //                    let graphic = self?.graphicForPoint(results[0].displayLocation!, attributes: results[0].attributes as [String : AnyObject]?)
                    //                    self?.graphicsOverlay.graphics.add(graphic!)
                else {
                    //provide feedback in case of failure
                    print("No GeoCode Result found.......)")
but this above code never gives result. and ends up with below error:
Some Times This::
testGeoCode Error::: Error Domain=NSCocoaErrorDomain Code=3072 "User canceled error" UserInfo={NSLocalizedDescription=User canceled error}
2018-09-02 13:12:36.204621+0300 ERS[8764:217712] Task <9EC69EBF-C7BE-45AF-8564-F6B607856D45>.<185> finished with error - code: -999
2018-09-02 13:12:36.204795+0300 ERS[8764:218992] Task <A6812BF2-37CC-4470-B0D0-5C53E5BD7FFD>.<184> HTTP load failed (error code: -999 [1:89])
2018-09-02 13:12:36.205268+0300 ERS[8764:217712] Task <A6812BF2-37CC-4470-B0D0-5C53E5BD7FFD>.<184> finished with error - code: -999
Some Times::
2018-09-02 13:20:07.760707+0300 ERS[9134:225343] Task <3C0CE309-4E55-4A3F-B62F-AD54EB132FA6>.<203> HTTP load failed (error code: -999 [1:89])
I am also performing Query:: using below Code:: -  (code is copied from ESRI-GitHub Sample Codes- for Query )
func testQueryOnLayer(){
        let featureTable = AGSServiceFeatureTable(url: URL(string: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2")!)
        let featureLayer = AGSFeatureLayer(featureTable: featureTable)
        featureLayer.selectionWidth = 5
        let searchText = "California"
        let queryParams = AGSQueryParameters()
        queryParams.whereClause = "upper(STATE_NAME) LIKE '%\(searchText.uppercased())%'"
        featureTable.queryFeatures(with: queryParams, completion: { (result:AGSFeatureQueryResult?, error:Error?) -> Void in
                print("testQueryOnLayer Error::: \(error)")
            else if let features = result?.featureEnumerator().allObjects {
                if features.count > 0 {
                    print("GeoCode Result found::: \(features.count)")
                    //mapView.setViewpointGeometry(features[0].geometry!, padding: 80, completion: nil)
                else {
                    print("No query Result found.......)")
This above code executes, neither gives error nor gives result.
NOTE:: I have already made changes into my info.plist file. to avoid ATS as below::
<key>NSAppTransportSecurity</key>
<dict>
<key>NSExceptionDomains</key>
<dict>
<key>arcgis.com</key>
<dict>
<key>NSIncludesSubdomains</key>
<true/>
<key>NSThirdPartyExceptionAllowsInsecureHTTPLoads</key>
<true/>
</dict>
<key>arcgisonline.com</key>
<dict>
<true/>
<true/>
</dict>
<key>esri.com</key>
<dict>
<true/>
<true/>
</dict>
</dict>
</dict>
Any Leads please.
NimeshJarecha
You are not holding on to the objects on which you are sending requests. Hence, things are not working as expected. Please look at the modified code below. The `locatorTask` and `featureTable` are declared as class level variables and now queries are successfully returns results.
    var locatorTask: AGSLocatorTask?
    func testGeoCode(){
        locatorTask = AGSLocatorTask(url: URL(string: locatorURL)!)
        locatorTask?.geocode(withSearchText: "California", parameters: geocodeParameters, completion: { (results:[AGSGeocodeResult]?, error:Error?) -> Void in
            else {
                else {
    var featureTable: AGSServiceFeatureTable?
        let featureLayer = AGSFeatureLayer(featureTable: featureTable!)
        featureTable?.queryFeatures(with: queryParams, completion: { (result:AGSFeatureQueryResult?, error:Error?) -> Void in
                else {
Hope this helps!
Regards,
Nimesh
