Can ArcGIS Pro integrate with JetBrains Pycharm
11290
5
08-14-2018 07:34 AM
AdrianGay
Dear Esri Users ….
Is it possible to integrate JetBrains PyCharm Developer environment into Arc GIS Pro for developments of GP tools and Python code?
If so, is there any guide line documentation how to set up Arc GIS Pro?
Many thanks
Tags (1)
DanPatterson_Retired
The anaconda distribution is pretty tight... conda installs of Spyder, Jupyter console and Jupyter notebook can be done since they are incorporated in the distribution.  Other IDE's are not and no one has reported using others successfully especially since the Pro 2.2 release.  Check my blog for the aforementioned IDEs installation and usage if you are not tied your ide
I will flag
Kory Kramer‌ and Shaun Walbridge‌ to see if they have any further input
JoshuaBixby
MVP Esteemed Contributor
Short answer, yes, I use PyCharm regularly with the bundled ArcGIS Pro Python distribution. Python in ArcGIS Pro—ArcPy Get Started | ArcGIS Desktop  and Configuring Python Interpreter - Help | PyCharm .  The two main issues are knowing where Pro installs its Python environments and how to point PyCharm there.
TomMcCann
Hi Josh – are you seeing any group discussions about the Arcade scripting language?
Tom... there are none formed.  Although you can put in a proposal for new one.
Perhaps they could call it "Avenue 2"
ShaunWalbridge
Adrian,
Yes, you can use PyCharm with ArcGIS Pro, its a commonly used IDE for working with ArcPy and the rest of the ArcGIS Python distribution. The Python distributed with Pro uses conda, and PyCharm has documentation on how to configure access to conda as its interpreter:
  Configuring Conda Environment - Help | PyCharm
Once you've configured that, just set it as the active interpreter for the project, and you should be off to the races. Let us know if you have any questions or issues.
Cheers,
Shaun
