find sample Reverse geocode | ArcGIS API for JavaScriptfor 4.8
8679
17
08-13-2018 08:45 PM
HsuKao-Ming
Hey gutys:
I want to find sample Reverse geocode | ArcGIS API for JavaScriptfor 4.8  than search[ lon, lat]  to address(not click map to address).
but I didn't find this
So where can I go to find this
Ask for help
THANKS
RobertScheitlin__GISP
Hsu,
   Your code:
var pt = new Point(x, y, new SpatialReference({ wkid: 4326 }));
was the way it was done in 3.x API. In the 4.x API you need to provide an object in the Point constructor that specifies the objects property names:
var pt = new Point({x: x, y: y, spatialReference: new SpatialReference({ wkid: 4326 })});
Here is an updated sample:
<!DOCTYPE html>
<html>
  <head>
    <title>Find Address</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map {
        padding: 0;
        border: solid 2px #666;
        margin: 0 5px 5px 5px;
      #header {
        color: #666;
        font-family: sans-serif;
        font-size: 1.1em;
        height: auto;
        margin: 5px;
        overflow: hidden;
        padding: 10px 0 10px 20px;
        text-align:left;
      .roundedCorners {
        -webkit-border-radius: 5px;
        -moz-border-radius: 5px;
        border-radius: 5px;
    </style>
    <script src="https://js.arcgis.com/4.8/"></script>
    <script>
      var map;
      require([
        "esri/Map", "esri/views/MapView", "esri/tasks/Locator", "esri/Graphic",
        "esri/geometry/support/webMercatorUtils",
        "esri/PopupTemplate", "esri/geometry/SpatialReference", "esri/geometry/Point",
        "dojo/number", "dojo/parser", "dojo/dom", "dojo/on",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, MapView, Locator, Graphic,
        webMercatorUtils,
        PopupTemplate, SpatialReference, Point,
        number, parser, dom, on
        parser.parse();
        map = new Map({
          basemap: "streets"
        var view = new MapView({
          container: "map",
          map: map,
          center: [-118.3, 34.2],
          zoom: 11
        var locator = new Locator("https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
        var infoTemplate = new PopupTemplate({
          title: "Location",
          content: "Address: {Address}"
        on(dom.byId('btnGo'), 'click', function(){
          var lon = dom.byId('Lon').value;
          var lat = dom.byId('Lat').value;
          var x = parseFloat(lon);
          var y = parseFloat(lat);
            x: x,
            y: y,
          locator.locationToAddress(pt, 100).then(function(evt){
            if (evt.address) {
              var address = {Address: evt.address};
              var location = webMercatorUtils.geographicToWebMercator(evt.location);
              var graphic = new Graphic({
                geometry: location,
                symbol: {
                  type: "simple-marker",  // autocasts as new SimpleMarkerSymbol()
                  color: "blue",
                  outline: {  // autocasts as new SimpleLineSymbol()
                    width: 0.5,
                    color: "darkblue"
                attributes: address,
                popupTemplate: infoTemplate
              view.graphics.add(graphic);
              //display the info window with the address information
              view.popup.open({
                features: [graphic],
        view.on("click", function(evt) {
          view.graphics.removeAll();
          console.info(webMercatorUtils.webMercatorToGeographic(evt.mapPoint));
          locator.locationToAddress(webMercatorUtils.webMercatorToGeographic(evt.mapPoint), 100).then(function(evt){
            if (evt.address) {
                geometry: location,
                symbol: {
                  color: "blue",
                    width: 0.5,
                    color: "darkblue"
              view.popup.open({
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%; height:100%;">
      <div id="header" class="roundedCorners"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'top'">
        <span>Click the map to get the address for the input location.</span>
        <input type='text' id='Lat' value="34.250812723611325"></input>
        <input type='text' id='Lon' value='-118.51732330322035'></input>
        <button type="button" id='btnGo'>Locate</button>
      </div>
      <div id="map" class="roundedCorners"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
Hsu,
  Here is the 3.x sample updated to 4.8:
<!DOCTYPE html>
<html>
  <head>
    <style>
      #map {
        padding: 0;
      #header {
        color: #666;
        font-size: 1.1em;
        height: auto;
        margin: 5px;
        overflow: hidden;
        text-align:left;
      .roundedCorners {
        border-radius: 5px;
    </style>
    <script>
      var map;
      require([
      ], function(
        webMercatorUtils,
        PopupTemplate,
        number, parser
        parser.parse();
        map = new Map({
          basemap: "streets"
          container: "map",
          map: map,
          zoom: 11
          title: "Location",
            if (evt.address) {
                geometry: location,
                symbol: {
                  color: "blue",
                    width: 0.5,
                    color: "darkblue"
              view.popup.open({
    </script>
  </head>
      </div>
      </div>
    </div>
  </body>
</html>
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
HsuKao-Ming
but I want "search[ lon, lat]  to address(not click map to address)"
this my code:
var locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
got error this :
Uncaught TypeError: c.indexOf is not a function
at Object.m (dojo.js:315)
at Object.set (dojo.js:228)
at Object.postscript (dojo.js:227)
at new <anonymous> (dojo.js:237)
at Location.js?20161027:381
at K (dojo.js:18)
at dojo.js:19
at E (dojo.js:19)
at da (dojo.js:19)
at e (dojo.js:21)
How can I do this ?
Hsu,
   Your code:
<!DOCTYPE html>
<html>
  <head>
    <style>
      #map {
        padding: 0;
      #header {
        color: #666;
        font-size: 1.1em;
        height: auto;
        margin: 5px;
        overflow: hidden;
        text-align:left;
      .roundedCorners {
        border-radius: 5px;
    </style>
    <script>
      var map;
      require([
      ], function(
        webMercatorUtils,
        parser.parse();
        map = new Map({
          basemap: "streets"
          container: "map",
          map: map,
          zoom: 11
          title: "Location",
            x: x,
            y: y,
            if (evt.address) {
                geometry: location,
                symbol: {
                  color: "blue",
                    width: 0.5,
                    color: "darkblue"
              view.popup.open({
            if (evt.address) {
                geometry: location,
                symbol: {
                  color: "blue",
                    width: 0.5,
                    color: "darkblue"
              view.popup.open({
    </script>
  </head>
      </div>
      </div>
    </div>
  </body>
</html>
HsuKao-Ming
Thank your help
I have two questions.
1.
this my code.
var x = parseFloat(-118.51732330322035);
var y = parseFloat(34.250812723611325);
x: x,
y: y,
if (evt.address) {
get error this:
Uncaught TypeError: a.clone(...).normalize is not a function
at Object.b.locationToAddress (Locator.js:8)
at Location.js?20161027:388
at K (dojo.js:18)
at dojo.js:19
at E (dojo.js:19)
at da (dojo.js:19)
at e (dojo.js:21)
at HTMLScriptElement.<anonymous> (dojo.js:23)
What have I ignored?
2.The sample you provided
I want to get "Match_addr" , but I can't
Why?
{"address":{"Match_addr":"17545 Lassen St, Northridge, California, 91325","LongLabel":"17545 Lassen St, Northridge, CA, 91325, USA","ShortLabel":"17545 Lassen St","Addr_type":"PointAddress","Type":"","PlaceName":"","AddNum":"17545","Address":"17545 Lassen St","Block":"","Sector":"","Neighborhood":"Northridge","District":"","City":"Northridge","MetroArea":"Los Angeles Metro Area","Subregion":"Los Angeles County","Region":"California","Territory":"","Postal":"91325","PostalExt":"","CountryCode":"USA"},"location":{"x":-118.51724250000001,"y":34.250362478792603,"spatialReference":{"wkid":4326,"latestWkid":4326}}}
Hsu,
  1. var x = parseFloat(-118.51732330322035);
You are telling the parseFloat function to parse a number (which make no sense). The parseFloat is for making a sting a number.
This would be correct:
var x = parseFloat('-118.51732330322035');
var y = parseFloat('34.250812723611325');
  2. Because Match_addr is not part of the evt object it is part of the evt.attributes object:
var address = {Address: evt.attributes.Match_addr};
HsuKao-Ming
THANK Your Tips.
but I have the 1 same error again.
mycode:
require([
"esri/Map",
"esri/widgets/Search",
"esri/Graphic",
"dojo/domReady!"
function(Map, MapView, Search,
Point,
SpatialReference, Locator
x: x,
y: y,
if (evt.address) {
get error this.
at K (dojo.js:18)
at dojo.js:19
at E (dojo.js:19)
at da (dojo.js:19)
at e (dojo.js:21)
Please help again.
THANKS
Hsu,
   Your requires are out of order:
require([
"esri/Map",
"esri/Graphic",
"dojo/domReady!"
function(
Map
MapView,
Search,
Point,
SpatialReference,
Locator
it should be:
require([
  "esri/Map",
  "esri/Graphic",
  "dojo/domReady!"
function(
  Map
  MapView,
  Search,
  Graphic,
  Point,
  Locator,
  SpatialReference,
  PopupTemplate
Notice, line 2  = line 13, 3 = 13, etc, etc
HsuKao-Ming
Thank your help.
My other two questions.
1. There is something wrong with the address returned by location. If I want to provide information and ask you to modify it.
What should I do?
Because some locations return the store name, it is not the address of the return details.
2.google api "timezone", is there a way to convert?
Hsu,
  1. I have never run into that situation. You have looked through all the attributes in the returned event and are sure the infomation you need is not returned right?
  2. "google api" ???....
