find sample Reverse geocode | ArcGIS API for JavaScriptfor 4.8
8719
17
08-13-2018 08:45 PM
HsuKao-Ming
Hey gutys:
I want to find sample Reverse geocode | ArcGIS API for JavaScriptfor 4.8  than search[ lon, lat]  to address(not click map to address).
but I didn't find this
So where can I go to find this
Ask for help
THANKS
HsuKao-Ming
Hi
1.YES.Some time return not correct address,return Commercial store name
So how can I do?
2.For your reference↓
Developer Guide  |  Time Zone API  |  Google Developers
I focus this↓
 the offset for daylight-savings time in seconds. This will be zero if the time zone is not in Daylight Savings Time during the specified timestamp.
RobertScheitlin__GISP
Hsu,
  1. Again. You have looked through all the attributes in the returned event and are sure the information you need is not returned right?
   2. Sorry I don't use the Google maps API so I can't help there.
HsuKao-Ming
Robert,
1.Again anwser YES,Not the same value returned by google.
  You can compare the latitude and longitude of a commercial vending shop.
2.Then, if you get the information obtained abroad, how to solve the time zone offset?
Can you provide an example of when a lat long returns a store name instead of an address? Example lat lon.
HsuKao-Ming
HI,Robert.
Try this example:
x:24.979867
y:121.549301
and then I got the new question.
 circle = new Circle({
 center: [lng,lat],
 geodesic: false,
 radius: 300, // 300 feet
 radiusUnit: "meters"
 view.graphics.add({
 symbol: {
 type: "simple-marker",
 color: [255,0,0,0.25],
 geometry:circle
symbol 's size and circle's radius,Which is the main influence on drawing information?
because I not set symbol 's size ,not draw circle
So how can I do?
Hsu,
   I don't read Taiwanese but I believe you need to use the LongLabel attribute to get the address.
新北市新店區寶興里寶中路119號安泰商業銀行, 231, TWN = Antai Commercial Bank, No. 119, Baozhong Road, Baoxing, Xindian District, New Taipei City, 231, TWN
var address = {Address: evt.attributes.LongLabel};
For new unrelated questions you need to start a new Question.
HsuKao-Ming
Robert,
Sorry,you try it again.
Test this
x:24.979990000000043
y:121.54915000000005
link :
https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/reverseGeocode?location=%7B%22sp...
The LongLabel is Not detailed,should be return '231新北市新店區寶中路94-112'
Hsu,
  I am not sure what to tell you. You say it should be:
231 94-112, Baozhong Road, Xindian District, New Taipei City
but the Geocode service returns
No. 1-3, Lane 113, Baozhong Road, Baoxing, Xindian District, New Taipei City, 231
There is no fixing this.
