Survey123.arcgis.com enable viewer access
854
08-13-2018 04:49 AM
FinnianO_Connor
I have a survey that uses the submission url parameter to direct data to a hosted feature layer view. I want to provide access to the data through survey123.arcgis.com but when i go to Collaborate and select the group I want to share the survey with I get an error saying  'view service cannot reference other view service'. Does this mean I cannot make the data available through the survey123.arcgis.com website to viewers?
Finniansurvey123.arcgis.com enable viewer error
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Finnian,
At this time you can't share for analysis (make available via the Survey123 website) a survey that uses submission_url pointed to a view.
JamesTedrick
Hi Finnian,
FinnianO_Connor
Thanks for the info James. It would be good to see this functionality made available in the future.
Cheers,
Finnian
