Existing feature class polygons help
1199
08-09-2018 07:50 PM
NaomiBegg2
I've heard that I should now be able to create a survey based of an existing feature class of polygons.
I only want to edit attributes rather than create/delete/move geometry so I thought this would be a great way to get more of our staff on board.
I created the survey using Connect, and it automatically put the geoshape field in.  I tried to use this and the survey wouldn't send due to incorrect geometry type.  I then read that you aren't meant to have a geometry field in for this so I took it out, but again I am still getting the same error.
Is this functionality actually supported?
IF so what am I doing wrong?!
NaomiBegg2
I was using version 2.4.72.  I have since updated to version 3.0.134.
This update has removed the incorrect geometry error.
However I am having an issue with survey123 not allowing spaces within select type answers which clashes with my previous data and doesn't look so good.
NaomiBegg2
