How to display loading icon when map is loading with API JavaScript 4 ?
9956
08-09-2018 04:40 AM
FlavieMORAUX1
Hy,
I need to display loading icon when map is loading.
With API JavaScript 3.X it is possible with map event's onUpdateStart/onUpdateEnd, like in following sample :
Show loading icon | ArcGIS API for JavaScript 3.25
Equivalent is not available in version 4, so how to do that ? Is there a way to do like in version 3 globally on Map (or View) ?
Regards,
Flavie
RobertScheitlin__GISP
Flavie,
   In 4.x you watch properties of the view like updating
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Intro to MapView - Create a 2D map - 4.8</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .visible {
      display: block !important;
    .loading{
      position: absolute;
      top: 100px;
      left: 100px;
      background-color: black;
      color: white;
      display: none;
      padding: 8px;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css">
  <script src="https://js.arcgis.com/4.8/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "dojo/dom-class",
      "dojo/domReady!"
    ], function(Map, MapView, domClass) {
      var map = new Map({
        basemap: "streets"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 4,
        center: [15, 65] // longitude, latitude
      view.watch('updating', function(evt){
        if(evt === true){
          domClass.add('loadingDiv', 'visible');
        }else{
          domClass.remove('loadingDiv', 'visible');
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="loadingDiv" class="loading">Updating...</div>
</body>
</html>
Flavie,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .visible {
    .loading{
      position: absolute;
      top: 100px;
      left: 100px;
      color: white;
      display: none;
      padding: 8px;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/dom-class",
      "dojo/domReady!"
      var map = new Map({
        basemap: "streets"
        map: map,
        zoom: 4,
        if(evt === true){
        }else{
  </script>
</head>
<body>
</body>
</html>
FlavieMORAUX1
I will use this property, thanks Robert Scheitlin, GISP‌!
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
