Can attribute tables be undocked by default?
2149
08-07-2018 02:14 PM
TonyStephens2
Pretty much trying to determine the question in the heading. Would prefer not to have it as a tab by default in part as it always the changes the layout i was working in to be the layout at whatever tab was last in line before the attribute table I have just dragged to my second monitor. Assuming it is not too difficult as this was/is possible in ArcMap.
DanPatterson_Retired
If you are talking ArcGIS Pro... then there is no default 'float' option and they open in the bottom of the screen by default with multiple open tables being tabs... unless you fiddle with the layout.
TonyStephens2
Thanks Dan. Thought that must be the case. I have in the meantime submitted this request to 'ArcGIS Ideas'.
good idea Tony
ThomasColson
