Graphic within GraphicLayer is undefined.
3091
9
08-09-2018 07:14 AM
DavidKucharski
I have a graphics layer that has a graphics length of 2 because I added 3 graphics. When I try to reference the graphicLayer.graphics[0] the system is telling me that it is undefined. If I have 3 graphics why would it be undefined?
RobertScheitlin__GISP
David,
   In the 4.x API the graphics property return a Collection not a flat array like the 3.x API did. SO you have to use collection methods.
//Old way in 3.x
graphicLayer.graphics[0];
//New way in 4.x
graphicLayer.graphics.getItemAt(0);
KenBuja
MVP Esteemed Contributor
Can you post the code showing how you define graphicsLayer and add the graphics to it?
David,
//Old way in 3.x
//New way in 4.x
DavidKucharski
The graphicLayer.graphics.getItemAt(0) works to get the graphic. Thank you. One last issue though. I am creating the graphic and adding it to the layer using the below code in bold. At the end I add 'id' as an attribute to uniquely identify it.
In another process, directly below, I loop through the graphic layer looking for a graphic with an 'id' value. I am getting errors when trying to access the attributes section.
for (gL = 0; highlightGeographyLyr.graphics.length; gL++) {
   if (highlightGeographyLyr.graphics.getItemAt(gl).attributes[0] == geography) {
            highlightGeographyLyr.remove(highlightGeographyLyr.graphics.getItemAt(gl));
function highLightGeography(response) {
// Loop through each of the results and assign a symbol and PopupTemplate
// to each so they may be visualized on the map
var geography = "";
var peakResults = arrayUtils.map(response.features, function (
feature) {
geography = feature.attributes.ID_;
// Sets the symbol of each resulting feature to a cone with a
// fixed color and width. The height is based on the mountain's elevation
feature.symbol = {
type: "simple-fill", // autocasts as new PointSymbol3D()
color: {
r: 245,
g: 245,
b: 245,
a: 0.5
style: "solid",
opacity: 0.2,
outline: { color: "white", width: 1 }
return feature;
peakResults.attributes = { "id": geography };
highlightGeographyLyr.addMany(peakResults);
David,
  Would it not be length - 1 in your for loop?
for (gL = 0; highlightGeographyLyr.graphics.length - 1; gL++) {
DavidKucharski
For 1 graphic in the layer, the below lines error and say it is undefined.
highlightGeographyLyr.graphics.getItemAt(0).attributes[0]
highlightGeographyLyr.graphics.getItemAt(0).attributes(0)
highlightGeographyLyr.graphics.getItemAt(0).attributes.id
David,
  Strange a Collection is a zero based index and the attributes are an Object so your first line should work.
DavidKucharski
I am actually comparing it in a for loop to the 'geography' which is a variable. The javascript blows up on the compare. In the immediate window, I try to see what the value is
It gives me a value of {...} in the immediate window so something seems to be there.
David,
  So you specify gL as your interator index and then you use gl (all lower case) this is an issue in JavaScript as it is case sensitive
DavidKucharski
Thank you and sorry about the javascript error. It is working now.
