How to reduced query result limit..?
7304
17
08-06-2018 10:02 AM
Rocky_
I am trying to query feature from service url. which having set  MaxRecordCount: 100000 ..
is there any possible way to reduced the limit for query results, cause this MaxRecordCount: 100000 giving me error of Timeout exceeded and Error performing query operation.
Can anyone please tell me how to solve this issue.
Thanks in advance..
JohnGrayson
Esri Alum
You can try using the 'start' and 'num' parameters to break up the queries into manageable numbers (Query | API Reference | ArcGIS API for JavaScript 4.8)   Providing a decent UX for >100,000 features can be tricky so might think about filtering the data as part or your query, or providing a some type of 'paging' UI.
Rocky_
Hello john,
   Can you please share me a snippet or sample for it..
JohnGrayson
Esri Alum
Hello Raj,
   can you please provide a simplified version of the specific portion of your code as a working codepen, jsbin, or similar, so we can see what you're trying?
RobertScheitlin__GISP
RAJ,
  You can set the esriConfig request timeout property.
https://developers.arcgis.com/javascript/latest/api-reference/esri-config.html#request
Rocky_
Hi Robert,
    can you please share a snippet, how to use this timeout property..?
require(["esri/config"], function(esriConfig) {
  esriConfig.request.timeout = 120000;
This will affect all queries made in that app.
Rocky_
Tried this one, but not working.. still got same error timeout exceeded...
RAJ,
   Then it could be that 2 minutes is still not long enough and you are getting into the seriously unacceptable user wait time.
Rocky_
so what is the possible solution for this..? can we reduced the result count to certain limit.. such as
max 5000 count per query
