WebGIS DR utility error "Cannot get the the Web GIS configuration"
4344
6
08-02-2018 12:46 PM
GirishYadav1
I am trying to create a backup of ArcGIS Enterprise 10.6 and store it on S3. when I run the WebGISDR utility on primary portal machine it throws an error stating "Cannot get the the Web GIS configuration".
I am able to create a backup of each individual component ArcGIS Server, Portal & Datastore separately. But with webgisdr it throws this error. What could be the cause of this error message?
Girish
Capital One
George_Thompson
Esri Notable Contributor
Did you update the webgisdr.properties file? Configure disaster recovery for ArcGIS Enterprise—Portal for ArcGIS (10.6) | ArcGIS Enterprise
I put my .config file in the same location as the export file. I got the same error till I move it to the folder specified in the file.
--- George T.
GirishYadav1
Thanks for the reply George Thompson
Yes, I updated the webgisdr.properties file according to the documentation.
Which ".config" file you are mentioning? I want to export the backup to AWS S3 bucket. Can you please elaborate on your solution?
George_Thompson
The wegisdr.properties file is the "config" file, sorry for any confusion.
I would start by making the export file a local drive first and run it. This would make sure that everything is working properly. Then after a successful export, I would make the changes to your S3 location.
Here is a screenshot of my local export location:
--- George T.
JonathanQuinn
Can you validate the federated servers? It's likely that one of them can't be validated, which means the DR tool can't reach it to check some settings/configurations.
GirishYadav1
Hi Jonathan,
Thanks for the reply, the issue has been resolved. updates in the security group fixed it. However, I am now facing another issue with webgisdr in us-west-2 region. I have updates the details in this post webgisdr not creating backups in us-west-2 region  please let me know if I am missing something.
Girish
CapitalOne
QaiserHassan_Mohammad
Hi Girish,
Could you please explain what you mean by "updates in the security group"? I am stuck at the same error.
Regards,
Qaiser
