Setting refresh interval Operations Dashboard for ArcGIS
12781
6
07-31-2018 12:02 AM
OdonchimegAyush
How do you configure operational dashboard (web) for ArcGIS Portal version 10.6?
I can see the setting -  refresh interval on operational dashboard desktop application.
Can i load web version of operational dashboard on desktop application?
OdonchimegAyush
Hi Derek,
Thank you for replying so quick.
I have solved the issue using https://ago-assistant.esri.com/# based below link.
https://community.esri.com/thread/209399-ops-dashboard-web-version-table-refresh
On premise Web Ops dashboard refreshing is working both map and tables data.
Support case:
ENH-000114171: Allow for related tables to be refreshed at a specified interval in Operations Dashboard
QA:  please let me know that this is the only way to configure it using AGO assistant.
ANSWER: using ArcGIS Online Assistant is currently the only way to set a refresh interval on a table for Operations Dashboard
DerekLaw
Esri Esteemed Contributor
Hi Odonchimeg,
> Setting refresh interval in operational dashboard (web) for ArcGIS Portal version 10.6?
This functionality is not available in the web browser Operations Dashboard app. You can set a layer refresh when you configure the web map in the Map Viewer.
No, this is not possible. The Windows Desktop version of Ops Dashboard uses operation views, while the web browser Ops Dashboard uses dashboard items. These are 2 different and separate things.
Hope this helps,
OdonchimegAyush
Hi Derek,
Support case:
HuongTran1
We set the refresh rate on the Map viewer to be every 15 sec the only thing is refreshing in our operation dashboard is the map itself and not all the other element connected to it.
BrittanyBurson
I am finding this same behavior. @HuongTran1 were you able to get your elements to auto refresh?
utenalarosa
@BrittanyBurson nope I haven't been able to have the elements auto refresh.
JackFanZhang
as of Aug 2025 ArcGIS Enterprise 11.3, I was able to do this by setting the layer auto refresh in the web map used by the Dashboard.
