Hi Jonathan,
How was the survey deleted, via AGO or via Connect? Was the feature service also deleted, or just the survey Form item?
Was the survey originally published via Connect or the Website? When items are deleted on AGO they can not be recovered. However if you have a copy of the survey in Connect, you can use the xlsx file to publish another survey and point it to the same existing feature service if it wasn't also deleted.
Phil.
