Listener for layer toggle widget
15759
68
07-20-2018 07:37 AM
MarkLache1
How would I add a listener to Robert's layer toggle widget that would be able to tell what layer is on? I want this so that the info can be passed into Survey123 via custom URL
RobertScheitlin__GISP
Mark,
   So where is your topic subscribe to the "toggleChanged" in the above code?..
      _publishMapEvent: function(map) {
        topic.subscribe('toggleChanged', lang.hitch(this, function(visible, layer){
           //console.info(visible, layer);
           if(visible){
             this.SERVICE_ID = layer.id;
        //add this property for debug purpose
        window._viewerMap = map;
        MapUrlParamsHandler.postProcessUrlParams(this.urlParams, map);
        console.timeEnd('Load Map');
        if (this.map) {
          this.map = map;
          this.resetInfoWindow(true);
          console.log('map changed.');
          topic.publish('mapChanged', this.map, this.layerInfosObj);
        } else {
          this.map = map;
          topic.publish('mapLoaded', this.map, this.layerInfosObj);
        require([
          'esri/graphic',
          'esri/symbols/SimpleMarkerSymbol',
          'esri/symbols/SimpleLineSymbol',
          'esri/Color'
        ], lang.hitch(this, function(Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color){
          var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
          map.on("click", lang.hitch(this, function(evt){
            map.graphics.clear();
            map.graphics.add(new Graphic(evt.mapPoint, symbol));
            map.infoWindow.setContent('<a href="https://survey123.arcgis.com/share/' + this.SERVICE_ID + '?center='+evt.mapPoint.getLatitude().toString() +","+ evt.mapPoint.getLongitude().toString()+'" target="_blank"><font size="4">Click here to submit a service request</font></a>');
            map.infoWindow.show(evt.mapPoint)
Mark,
   Where will you be listening to this event from? Another widget?
MarkLache1
Not necessarily. Just need to capture the layer (or if the toggle is on or off) so that I can use it in Survey123 to populate a question. Will be used to determine if on main floor or second floor of a building
Mark,
   The 2.8 version of the layer toggle button dispatches a "toggleChanged" event that can be listened to using dojo/topic subscribe in your code.
MarkLache1
How would I incorporate this into my app?
Mark,
  As I mentioned in my last post you would add the require for dojo/topic and then use topic.subscribe('toggleChanged', function(){ //your code });
MarkLache1
Which file in the WAB structure do I incorporate this?
Do you have a larger code example?
Mark,
   No I do not have a sample for this. You implement the dojo topic subscribe in whatever file that you will need to do something with the event in.
MarkLache1
I just need to capture which layer is turned on (in my case its floor 1 or floor 2 of a building) and ad this into the URL to pass into Survey123. Not really doing anything with it in WAB
Mark,
   Well you need to listen for this event somewhere so that you add it to your url.. So I guess you can do that in the MapManager.js or some file that is used automatically in WAB.
