Listener for layer toggle widget
7748
68
07-20-2018 07:37 AM
MarkLache1
How would I add a listener to Robert's layer toggle widget that would be able to tell what layer is on? I want this so that the info can be passed into Survey123 via custom URL
MarkLache1
Each layer is its own service
RobertScheitlin__GISP
Mark,
   OK, I tried to adding a second map service and I still don't get undefined.
MarkLache1
Robert,
Now the other layer I have is conflicting with my layer in question. By this I mean that the secondary layers in another toggle button are conflicting with my main toggle button (only one I need the listener on). The secondary toggle takes over the listener and that layer name is retuned instead.
Mark
Mark,
 Each toggle widget will send the toggle event. There is no way for one to publish the event and the other not.
MarkLache1
Robert,
Have a workaround in mind?
Thanks, Mark
Check if it is the layer you are interested in before you act on the event.
MarkLache1
Something like this?
_publishMapEvent: function(map) {
        topic.subscribe('toggleChanged', lang.hitch(this, function(visible, layer){
          if(visible && layer.title=building1){
            this.SERVICE_ID = layer.title;
          // create node for the tooltip
          var tip = "Click on problem location";
          var tooltip = dojo.create("div", { "class": "tooltip", "innerHTML": tip }, map.container);
          dojo.style(tooltip, "position", "fixed");
          // update the tooltip as the mouse moves over the map
          dojo.connect(map, "onMouseMove", function(evt) {
            var px, py;
            if (evt.clientX || evt.pageY) {
              px = evt.clientX;
              py = evt.clientY;
            } else {
              px = evt.clientX + dojo.body().scrollLeft - dojo.body().clientLeft;
              py = evt.clientY + dojo.body().scrollTop - dojo.body().clientTop;
            // dojo.style(tooltip, "display", "none");
            tooltip.style.display = "none";
            dojo.style(tooltip, { left: (px + 15) + "px", top: (py) + "px" });
            // dojo.style(tooltip, "display", "");
            tooltip.style.display = "";
            // console.log("updated tooltip pos.");
          // hide the tooltip the cursor isn't over the map
          dojo.connect(map, "onMouseOut", function(evt){
        //add this property for debug purpose
        window._viewerMap = map;
        MapUrlParamsHandler.postProcessUrlParams(this.urlParams, map);
        console.timeEnd('Load Map');
        if (this.map) {
          this.map = map;
          this.resetInfoWindow(true);
          console.log('map changed.');
          topic.publish('mapChanged', this.map, this.layerInfosObj);
        } else {
          this.map = map;
          topic.publish('mapLoaded', this.map, this.layerInfosObj);
        require([
          'esri/graphic',
          'esri/symbols/SimpleMarkerSymbol',
          'esri/symbols/SimpleLineSymbol',
          'esri/Color'
          lang.hitch(this, function(Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color){
          var symbol = new SimpleMarkerSymbol(
         SimpleMarkerSymbol.STYLE_CIRCLE, 0.01,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_CIRCLE,
            new Color([207, 16, 45, 0.9]),
          map.on("click", lang.hitch(this, function(evt){
            var gra = new Graphic(evt.mapPoint, symbol);
            setTimeout(lang.hitch(this, function(){
              var selFeats = map.infoWindow.features;
              if(!selFeats){
                map.graphics.clear();
                map.graphics.add(gra);
                    //PopupCenter('http://www.xtf.dk','xtf','900','500');
                map.infoWindow.setContent('<a href="https://survey123.arcgis.com/share/xyz123?center='+ evt.mapPoint.getLatitude().toString() + ','+ evt.mapPoint.getLongitude().toString() + '&field:Floor_Selection=' + this.SERVICE_ID.split('_')[1]+"_Floor " + '" target="_parent"><font size="4">Click here to submit a service request</font></a>');
                    SERVICE_ID: null;
                map.infoWindow.show(evt.mapPoint);
            }), 1000);
Mark,
   Yes but you need to fix your condition logic.
if(visible && layer.title === 'building1'){
MarkLache1
Thanks it worked
