Listener for layer toggle widget
15977
68
07-20-2018 07:37 AM
MarkLache1
How would I add a listener to Robert's layer toggle widget that would be able to tell what layer is on? I want this so that the info can be passed into Survey123 via custom URL
RobertScheitlin__GISP
Mark,
   Strange back in this post of your you were showing that the layer was not undefined:
https://community.esri.com/message/794280-re-listener-for-layer-toggle-widget?commentID=794280#comme...
MarkLache1
Very strange. I could see the listener working as I switched between the layers each button click (initially in the console). Nothing has changed on my end in terms of services or the layers themselves. These layers are hosted on AGOL without any weird parameters.
Mark,
  So now the layer object is always null when you toggle a layer?
MarkLache1
Fixed it! Was missing the declaration for LayerStructure.
The SERVICE_ID is returning the layer name as expected, but its also retuning a number after the layer name. Also, how can a split function be used on this.SERVICE_ID?
Just like you would any other string.
MarkLache1
Everything else works but now I get undefined when I switch to my 2nd layer
  _publishMapEvent: function(map) {
        topic.subscribe('toggleChanged', lang.hitch(this, function(visible, layer){
          if(visible){
            this.SERVICE_ID = layer.id;
        //add this property for debug purpose
        window._viewerMap = map;
        MapUrlParamsHandler.postProcessUrlParams(this.urlParams, map);
        console.timeEnd('Load Map');
        if (this.map) {
          this.map = map;
          this.resetInfoWindow(true);
          console.log('map changed.');
          topic.publish('mapChanged', this.map, this.layerInfosObj);
        } else {
          this.map = map;
          topic.publish('mapLoaded', this.map, this.layerInfosObj);
        require([
          'esri/graphic',
          'esri/symbols/SimpleMarkerSymbol',
          'esri/symbols/SimpleLineSymbol',
          'esri/Color'
        ], lang.hitch(this, function(Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color){
          var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
          map.on("click", lang.hitch(this, function(evt){
            var gra = new Graphic(evt.mapPoint, symbol);
            setTimeout(lang.hitch(this, function(){
              var selFeats = map.infoWindow.features;
              if(!selFeats){
                map.graphics.clear();
                map.graphics.add(gra);
                map.infoWindow.setContent('<a href="https://survey123.arcgis.com/share/5f16c4f6ce6f42aebf09e145eabe5674?center='+ evt.mapPoint.getLatitude().toString() + ','+ evt.mapPoint.getLongitude().toString() + '&field:Floor_Selection='+ this.SERVICE_ID.split('$')[1]  + '" target="_blank"><font size="4">Click here to submit a service request</font></a>');
                map.infoWindow.show(evt.mapPoint);
            }), 1000);
Mark,
  Are you sure that your second layer ID has a '$' in it?
MarkLache1
Used layer.title instead. Got it all working Thanks!
MarkLache1
If I have more than 2 layers in the layer toggle the result that is spit out "undefined". I only need the same 2 of the 6 layers to be examined for toggle change.
Mark,
   I have 4 toggle layers in my app and I do not see that issue. My situation is that the 4 layers are part of the same Map Service though. What is your scenario?
