Listener for layer toggle widget
8711
68
07-20-2018 07:37 AM
MarkLache1
How would I add a listener to Robert's layer toggle widget that would be able to tell what layer is on? I want this so that the info can be passed into Survey123 via custom URL
MarkLache1
All I really need to do is capture the layer name that is currently on in a text string. Something like:
topic.subscribe('toggleChanged', function()
   var URL =….;
Or just a way to identify one layer from another. Even having an ID of 1 when the button is off and an ID of 2 when the toggle button is turned on.
Suggestions?
RobertScheitlin__GISP
Mark,
   Something like:
topic.subscribe('toggleChanged', function(event){
   console.info(event);
//Now that you can see the contents of the event in your browsers console
//you will know what to add to your url.
   var URL ='…';
MarkLache1
I've tried pushing this to the console and I keep getting "Cross-Origin Request Blocked" errors. I'm using publishMapEvent function
Mark,
   Show me all the code from your modified publishMapEvent function.
MarkLache1
_publishMapEvent: function(map) {
        //add this property for debug purpose
        window._viewerMap = map;
        MapUrlParamsHandler.postProcessUrlParams(this.urlParams, map);
          console.log(event)
        console.timeEnd('Load Map');
        if (this.map) {
          this.map = map;
          this.resetInfoWindow(true);
          console.log('map changed.');
          topic.publish('mapChanged', this.map, this.layerInfosObj);
        } else
          this.map = map;
          topic.publish('mapLoaded', this.map, this.layerInfosObj);
Mark,
   That change would not produce a cross origin error.
Here is what I have working fine in that exact function:
        topic.subscribe('toggleChanged', function(visible, layer){
           console.info(visible, layer);
        if (this.map) {
          this.map = map;
        } else {
          this.map = map;
MarkLache1
Get the same error "Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at..." but only when I click the layer toggle widget. Get this error twice
Mark,
  I have no idea where that error is coming from. Does it prevent your app from working?
MarkLache1
App still works fine. Just need this to identify if the toggle is on or off.
MarkLache1
Don't know if it makes a difference but I am running it thru local host WAB
