Migrating code from ArcGIS Desktop python 2.7.3 to ArcGIS Pro python 3.6.2
3148
07-18-2018 12:25 AM
SyedGardezi
I am calling the following function:
import arcpy
arcpy.JoinField_management(in_data,in_field,join_table,join_table_field,fields)
It works perfectly fine using ArcGIS Desktop python 2.6 but gives the following trace using ArcGIS Pro python arcgispro-py3
input parameters:
  temp_layer,
  NEAR_FID,
  xyz.gdb\xyz\xyz,
  OBJECTID,
  dict_values(['xyz']
    raise e
    retval = convertArcObjectToPythonObject(gp.JoinField_management(*gp_fixargs((in_data, in_field, join_table, join_field, fields), True)))
    return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Object: Error in executing tool
I check I passed exactly  the same varabiels to both function but I am getting this error. can you give soem hints as to what might be the issue?
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting  rather than screen grabs
should be used to check for 2 to 3 changes in tool parameters etc
SyedGardezi
Thanks Dan Patterson, gdb name wasnt unicode string for Pythin 3! Fixing it solved the issue. Thanks for sharing the tool I will use it.
JoshuaBixby
MVP Esteemed Contributor
Is this code being run in the interactive Python window of ArcMap and ArcGIS Pro or standalone script?
SyedGardezi
Its standalone script.
