Python Scripting for Map Automation Practice
1792
07-17-2018 08:03 PM
JeremiahGbolagun1
>>> mxd = arcpy.mapping.MapDocument("CURRENT")
>>> df = arcpy.mapping.ListDataFrames(mxd, "City of Plains View")[0]
Runtime error
I am having problem running the above lines of code on ArcMap 10.5.1. Can you please let me where I have been having problem to run it.
Regards,
Jeremiah.
Tags (1)
BenjaminMittler
Is your data frame called exactly "City of Plains View"?
JeremiahGbolagun1
Yes it is called City of Plains View.
DanPatterson_Retired
So to ask the obvious... was arcmap open with that project open?
Also check for a trailing or preceding space in the dataframe name if capitalization is correct
