How to display attribute values when clicking a point from a feature server?
3197
07-13-2018 06:37 AM
KyleSchultz
I want to click on a point to display attributes from a feature server.  The only tutorial/sample I could find was from App Studio v1.4  sample on github and too much has changed to get it working.
Currently my code looks like this
        onMouseClicked: {
            var tolerance = 22;
            var returnPopupsOnly = false;
            var maximumResults = 1;
            mapView.identifyLayerWithMaxResults(featureLayer, mouse.x, mouse.y, tolerance, returnPopupsOnly, maximumResults);
        onIdentifyLayerStatusChanged: {
            if (identifyLayerStatus === Enums.TaskStatusCompleted) {
                featureLayer.clearSelection();
                var identifiedObjects = [];
                for (var i = 0; i < identifyLayerResult.geoElements.length; i++){
                    var elem = identifyLayerResult.geoElements[i];
                    identifiedObjects.push(elem);
                var count = identifyLayerResult.geoElements.length;
                featureLayer.selectFeatures(identifiedObjects);
Which is just code I took from the selecting feature app sample.
I have this code
                        onSelectFeaturesStatusChanged: {
                            if (selectFeaturesStatus === Enums.TaskStatusCompleted) {
                                if (!selectFeaturesResult.iterator.hasNext)
                                    return;
                                selectedFeature = selectFeaturesResult.iterator.next();
                                value= selectedFeature.attributes.attributeValue("attributeValue");
                                console.log(value)
but it does not get invoked because selectFeatures apparently doesn't call
onSelectFeaturesStatusChanged?
I find this all very frustrating, this should be extremely simple to do but there is no documentation that has been properly maintained
That even suggests how to properly accomplish this.
nakulmanocha
Hi Kyle,
Sorry to hear that. Yes it is quite simple to get attributes from the GeoElement. GeoElement has a sub class called Feature and Feature provides a property called attributes which is a ListModel (the model name is AttributeListModel in Runtime) that has the attribute names and value listed.
However, showing it in a dialog or a popup is a UI aspect and it can vary on the users requirement. This can be done in many ways.
AttributeListModel QML Type | ArcGIS for Developers
But just to give you a proof of concept I have provided a code snippet below for you to show how we can tweak the Feature Layer Selection Sample to show the feature attributes when you click on the feature. In this sample I have added a Dialog known as Pane which show all the attribute values along with the name using the AttributeListModel to show the attributes.
property real scaleFactor: AppFramework.displayScaleFactor
    property string displayText: "Click or tap to select features."
    ListModel{
    // Map view UI presentation at top
    MapView {
        anchors {
            left: parent.left
            right: parent.right
            top: parent.top
            bottom: messageBar.top
        wrapAroundMode: Enums.WrapAroundModeDisabled
        Map {
            BasemapStreets {}
            FeatureLayer {
                selectionColor: "cyan"
                selectionWidth: 3
                // feature table
                ServiceFeatureTable {
                    url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/DamageAssessment/FeatureServer/0"
            onLoadStatusChanged: {
                if (loadStatus === Enums.LoadStatusLoaded) {
                    mapView.setViewpoint(viewPoint);
        // initial viewpoint
        ViewpointCenter {
            Point {
                x: -10800000
                y: 4500000
                spatialReference: SpatialReference {
                    wkid: 102100
            targetScale: 3e7
        //! [identify feature layer qml api snippet]
        onMouseClicked: {
            var tolerance = 22;
            var maximumResults = 1000;
                // clear any previous selections
                displayAttributesModel.clear();
                // create an array to store the features
                    var elem = identifyLayerResult.geoElements;
                    displayAttributesModel.append(elem);
                // cache the number of identifyLayerResult
                // select the features in the feature layer
                displayText = "%1 %2 selected.".arg(count).arg(count > 1 ? "features" : "feature");
        // Busy Indicator
        BusyIndicator {
            anchors.centerIn: parent
            height: 48 * scaleFactor
            width: height
            running: true
            Material.accent:"#8f499c"
            visible: (mapView.drawStatus === Enums.DrawStatusInProgress)
    Pane {
        Material.primary: "white"
        Material.elevation:2
        padding: 5 * scaleFactor
        visible: displayAttributesModel.count > 0
        x: 10 * scaleFactor
        y: 10 * scaleFactor
        SwipeView{
            implicitHeight: 150 * scaleFactor
            implicitWidth: 175 * scaleFactor
            clip: true
            Repeater {
                model:displayAttributesModel
                Rectangle{
                    color: "white"
                    clip: true
                    Flickable {
                        anchors.fill:parent
                        contentWidth:parent.width
                        contentHeight: popupColumn.height
                        clip: true
                        flickableDirection: Flickable.VerticalFlick
                        ColumnLayout {
                            width: parent.width *  0.95
                            anchors.horizontalCenter: parent.horizontalCenter
                            spacing: 3 * scaleFactor
                            clip: true
                            Text {
                                Layout.preferredWidth:  parent.width
                                text: attributes.attributeValue("objectid")
                                elide: Text.ElideRight
                                color: "red"
                                font {
                                    family: "serif"
                                    pixelSize: 14 * scaleFactor
                                    bold: true
                                renderType: Text.NativeRendering
                            Rectangle {
                                Layout.preferredHeight: 2 * scaleFactor
                                color: "black"
                            Repeater {
                                model: attributes
                                RowLayout {
                                    Layout.fillWidth: true
                                    clip: true
                                    spacing: 5 * scaleFactor
                                    Text {
                                        Layout.preferredWidth: popupColumn.width * 0.55
                                        Layout.fillHeight: true
                                        text:  attributeName
                                        wrapMode: Text.WrapAnywhere
                                        font.pixelSize: 12 * scaleFactor
                                        color: "gray"
                                    Text {
                                        text:attributeValue
                                        color: "#4f4f4f"
    Rectangle {
        anchors {
            left: parent.left
            right: parent.right
            bottom: parent.bottom
        height: 30 * scaleFactor
        color: "lightgrey"
        border {
            width: 0.5 * scaleFactor
            color: "black"
        Text {
            anchors {
                verticalCenter: parent.verticalCenter
                left: parent.left
                leftMargin: 10 * scaleFactor
            text: displayText
            font.pixelSize: 14 * scaleFactor
If you notice in the code I added a SwipeView within the Pane to accommodate multiple selected features. Hence you can swipe horizontally to get to the next feature attributes if you would like.
I hope you find this useful. Thank you.
Nakul
nakulmanocha
Hi Kyle,
    ListModel{
    MapView {
        anchors {
            left: parent.left
            right: parent.right
            top: parent.top
        Map {
            BasemapStreets {}
            FeatureLayer {
                selectionWidth: 3
                // feature table
        ViewpointCenter {
            Point {
                x: -10800000
                y: 4500000
                    wkid: 102100
            targetScale: 3e7
        onMouseClicked: {
            var tolerance = 22;
        // Busy Indicator
        BusyIndicator {
            width: height
            running: true
    Pane {
        x: 10 * scaleFactor
        y: 10 * scaleFactor
        SwipeView{
            clip: true
            Repeater {
                Rectangle{
                    color: "white"
                    clip: true
                    Flickable {
                        anchors.fill:parent
                        clip: true
                        ColumnLayout {
                            clip: true
                            Text {
                                color: "red"
                                font {
                                    family: "serif"
                                    bold: true
                            Rectangle {
                                color: "black"
                            Repeater {
                                model: attributes
                                RowLayout {
                                    clip: true
                                    Text {
                                        text:  attributeName
                                        color: "gray"
                                    Text {
                                        text:attributeValue
                                        color: "#4f4f4f"
    Rectangle {
        anchors {
            left: parent.left
            right: parent.right
        color: "lightgrey"
        border {
            color: "black"
        Text {
            anchors {
                left: parent.left
            text: displayText
Nakul
KyleSchultz
What libraries are you importing to get this to work?
nakulmanocha
If you are using Appstudio 3.0. Then the sample should have the libraries listed below
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtQuick.Layouts 1.1
import QtQuick.Controls.Material 2.1
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.2
KyleSchultz
Thank you for your response
Is it possible to control which values are displayed? I don't want some of the fields being displayed visible
