Can I programmatically select a feature using 4.x?
1745
07-12-2018 10:03 AM
JasonBrowning
I'm trying to create a "zoom to" function for a list of features that are in a popup related to a currently selected "parent" feature. I can zoom to the feature just fine, but I don't know how to select it. So...given lat/long, is there a way to select a feature? I know 3.x had a selectFeatures function, but I'm not sure if that or something similar exists in 4.x. If not, is there another way to do it? Do I just need to programmatically click the map at the lat/long coordinates and make sure I'm in the right layer? Any assistance is greatly appreciated!
-Jason
RobertScheitlin__GISP
Jason,
   Highlighting a feature in 4.x is still not fully supported but look at this link:
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-layers-FeatureLayerView.htm...
If you are not asking about highlighting a feature on the map and just want to show it's popup then you would do a query on the layer using the lat/lon to create a point as the queries geometry and then set the views popup using the returned feature.
AingeruArmendariz
Is this supported by now? I would like to programmatically make a selection of features by their GlobalIds or any other property.
Thanks in advance
