Not able to read a streaming service
1130
07-11-2018 10:42 AM
EhabAlmoaibed
I created a streaming service which reads from a feature layer. Input/output/GeoEvent Process were all created and I can see they are updating in Monitoring tab.
the issue is when I try to consume this streaming service through portal, I don't see the points. and I got the following error on GeoEvent Manager log (all other logs in portal and AGS are clear)
org.eclipse.jetty.servlet.ServletHandler
Request(GET https://myserver.organziation.COM:6143/arcgis/ws/services/stream-service-out-vesseles-wkid4326/Strea...
/arcgis/ws/services/stream-service-out-vesseles-wkid4326/StreamServer/subscribe java.lang.NullPointerException at com.esri.arcgis.discovery.stream.StreamServlet.authenticateFederated(StreamServlet.java:398) [24:com.esri.arcgis.discovery.arcgis-stream-container:10.6.0] at com.esri.arcgis.discovery.stream.StreamServlet.checkSecurity(StreamServlet.java:433) [24:com.esri.arcgis.discovery.arcgis-stream-container:10.6.0] at com.esri.arcgis.discovery.stream.StreamServlet.getStreamServiceByFolderAndServiceName(StreamServlet.java:862) [24:com.esri.arcgis.discovery.arcgis-stream-container:10.6.0] at com.esri.arcgis.discovery.stream.StreamServlet.getStreamServiceFromURL(StreamServlet.java:291) [24:com.esri.arcgis.discovery.arcgis-stream-container:10.6.0] at com.esri.arcgis.discovery.stream.StreamSocketCreator.createWebSocket(StreamSocketCreator.java:44) [24:com.esri.arcgis.discovery.arcgis-stream-container:10.6.0] at org.eclipse.jetty.websocket.server.WebSocketServerFactory.acceptWebSocket(WebSocketServerFactory.java:187) [414:org.eclipse.jetty.websocket.server:9.3.14.v20161028] at org.eclipse.jetty.websocket.server.WebSocketServerFactory.acceptWebSocket(WebSocketServerFactory.java:172) [414:org.eclipse.jetty.websocket.server:9.3.14.v20161028] at org.eclipse.jetty.websocket.servlet.WebSocketServlet.service(WebSocketServlet.java:155) [415:org.eclipse.jetty.websocket.servlet:9.3.14.v20161028] at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [226:javax.servlet-api:3.1.0] at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845) [404:org.eclipse.jetty.servlet:9.3.14.v20161028] at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [404:org.eclipse.jetty.servlet:9.3.14.v20161028] at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:72) [435:org.ops4j.pax.web.pax-web-jetty:6.0.3] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [401:org.eclipse.jetty.security:9.3.14.v20161028] at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [435:org.ops4j.pax.web.pax-web-jetty:6.0.3] at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [404:org.eclipse.jetty.servlet:9.3.14.v20161028] at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [435:org.ops4j.pax.web.pax-web-jetty:6.0.3] at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.server.Server.handle(Server.java:534) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:320) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [403:org.eclipse.jetty.server:9.3.14.v20161028] at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273) [395:org.eclipse.jetty.io:9.3.14.v20161028] at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95) [395:org.eclipse.jetty.io:9.3.14.v20161028] at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:202) [395:org.eclipse.jetty.io:9.3.14.v20161028] at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273) [395:org.eclipse.jetty.io:9.3.14.v20161028] at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95) [395:org.eclipse.jetty.io:9.3.14.v20161028] at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [395:org.eclipse.jetty.io:9.3.14.v20161028] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [406:org.eclipse.jetty.util:9.3.14.v20161028] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [406:org.eclipse.jetty.util:9.3.14.v20161028] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [406:org.eclipse.jetty.util:9.3.14.v20161028] at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [406:org.eclipse.jetty.util:9.3.14.v20161028] at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [406:org.eclipse.jetty.util:9.3.14.v20161028] at java.lang.Thread.run(Thread.java:748) [?:?]
I tried to figure out the cause of the issue but no luck, any help is appreciated
WillStafford1
This is showing up for the installation of Geoevent Server 10.6.1 with portal and using SSL in house certificates.
Did you get this working
