Pro crashes when trying to open a specific project
4747
19
07-11-2018 08:22 AM
IngridMans
I have a primary Arc Pro project which contains all of my main content that I use on a daily basis. Ever since upgrading to 2.2, Pro crashes whenever I open that project on startup of Pro, with the error message that ArcGIS Pro encountered a serious issue and could not continue and the option to send an error report.
If I open a different project, however, and from there open the problem project, it is fine. I have been unable to identify what the issue is with that project file or contents.
XanderBakker
Esri Esteemed Contributor
I guess the best thing to do is report the issue with Esri support.
IngridMans
I've submitted the error report numerous times now when the the crash happens, but I cannot tell if it is getting pushed through.
XanderBakker
It is best to contact Esri Support directly and create a case and not just submit the error report.
DanPatterson_Retired
And try saving the project with a new name and location in case it becomes completely unuseable.  Exporting the data to new copies would also be prudent
kathyhardinwalker
I have a similar issue, when editing, my document crashes over and over. Does anyone experience this as well?
Kathy
MichaelVolz
Are you also working with Pro 2.2?
What kind of data are you editing when the document crashes (e.g. SDE database, file gdb, shapefile, other)?  Do the crashes always occur with the same data source type?
If the data you are having problems editing is on a network, can you try copying the data local to see if that prevents Pro from crashing?  If that is the case, then you would have a use case to show ESRI so they can work on the fundamental issue of using Pro to edit data on a network.
kathyhardinwalker
Yes Pro 2.2
Data type: feature class
I don't know (always occur with the same data source type). It seems to always happen when editing.
It is on a network.
Yes, I will try copying to see if that stops the problem.
Thank you,
Kathy
MichaelVolz
Is is a feature class in an SDE geodatabase or a file geodatabase?
If it's in an SDE geodatabase, is it SQL Server, Oracle or other?
Did these crashes occur in previous versions of Pro?
kathyhardinwalker
It is a SDE gdb on a SQL Server.
Kathy
