Point density - Errors
6381
12
07-11-2018 11:47 PM
LorenFreslaud
Hello Esri Community,
I would like to do a Density population map for my thesis but I had 2 errors when I tried :
1. ERROR 01038 Syntax error at or near symbol NEW-LINE
I precised that DDminimum does come from a polygone but convex hull (Minimum geometry boundary tool).
2. ERROR 010267 Syntax error in parsing grid expression
I did the Environment setting (attached). Environments > Raster analysis
Looking forward to hearing your feedbacks !
Thank you,
Loren
ERROR near symbol NEW-LINE + parsing grid expression
LorenFreslaud
Is anybody could help please ?
DanPatterson_Retired
The tool inputs would be more useful.
It looks like you may have a file path that has a space, international characters, or punctuation or the filename itself.
LorenFreslaud
Dear Dan,
Thanks for replying. I started to desperate!
I removed the space from output raster destination, but another error appeared : "unable to open the mask raster ".
"Home range" (previsously called DDminimum) is a file from Minimum geometry boundary tool.
ERROR near symbol NEW-LINE + open mask raster
Do you have an idea ?
c:\Users\Lo'\Documents\MSc WCM\Msc….
punctuation after Lo and space after MSc  can't see the rest.
Try moving everything out of the Users folder... maybe C:\GIS
XanderBakker
Esri Esteemed Contributor
It also seems that you have background processing switched on. If the process still does not work with the suggestions provided by Dan, you should try and switch off the background processing:
and
LorenFreslaud
Thank you Dan and Xander for answering !
I changed my folder emplacement and switch off the tick in Background processing
However the error "parsing grid expression" appeared ?
ERROR parsing grid expression
We will success soon I am sure !
Can you show the actual tool dialog input Loren, not where you searched for Point Density.
Point Density—Help | ArcGIS Desktop
ie. the input file, the population field and any other optional parameters.
You do have the Spatial Analyst extension enabled as well?
LorenFreslaud
I have the Spatial analyst extension.
Point density toolbox
From Point density toolbox :
Environment - Raster analysis - Mask
You aren't working with projected data.
The cell size and circle radius units suggest this.
I would use projected data for the inputs.
As for the mask, for now, drop the mask to see if it works without the mask.
Simply use Select by Attributes to select the points that fall within the convex hull and save those as a new (projected) point file.
As for the output... make it a *.tif file avoid an esri grid... simply add tif to the end of the file name once you have chosen your saving location.
I think it is a combination of not using projected data for the inputs and perhaps the mask
