Point density - Errors
6882
12
07-11-2018 11:47 PM
LorenFreslaud
Hello Esri Community,
I would like to do a Density population map for my thesis but I had 2 errors when I tried :
1. ERROR 01038 Syntax error at or near symbol NEW-LINE
I precised that DDminimum does come from a polygone but convex hull (Minimum geometry boundary tool).
2. ERROR 010267 Syntax error in parsing grid expression
I did the Environment setting (attached). Environments > Raster analysis
Looking forward to hearing your feedbacks !
Thank you,
Loren
ERROR near symbol NEW-LINE + parsing grid expression
NeilAyres
And this little snip seems to show that the data points are all on the home range boundary.
LorenFreslaud
Dear Neil,
Thank you for answering. I created a new layer, DD poly, larger than the home range boundary
DD poly
But this mask did not work for the point density.. (answer below) 😕
LorenFreslaud
Dear All,
It's worked ! any advice to modify my rectangle Point Density (DDdensity) like my DD poly (in transparent) ?
When I selected Mask > DDpoly it repeat th same error :
Rectangle raster
Thank you for your help and support !
