Map is not showing in ArcGIS API for Python demo test.
17313
29
07-03-2018 08:13 AM
by Anonymous User
Not applicable
Getting started with ArcGIS API for Python, and something seems amiss. I was hoping to simply get to the point where I could see a simple map and feel a nice sense of progress, but, while I get no error messages when I try to display the map, I also get no map.
This is probably something VERY simple, but I haven't been able to figure out under my own power. See image, please.
Thank you,
Randy McGregor
DarrenWiens2
I assume you've tried it without the 'oops' part?
by Anonymous User
Not applicable
The next line after the OOPS corrects it.
DarrenWiens2
Hmmmm, the following works for me:
from arcgis.gis import GIS
gis = GIS()
map = gis.map("Paris")
map‍‍‍‍‍‍‍‍
by Anonymous User
Not applicable
I am revisiting this. I have tried doing this in the sandbox, and I got the following. Does this provide any clues as to what the issue might be?
by Anonymous User
Not applicable
Thanks for checking. I'm missing something. I just don't know what...
DarrenWiens2
It's probably some difference in our environments. You're running on Python 3 kernel?
JeffBigos
Hi Randy,
What version of the api do you have installed?
You can check with the following code
import arcgis
print(__arcgis.version__)
JoshuaBixby
MVP Esteemed Contributor
The syntax is print(arcgis.__version__)
JeffBigos
Thanks for the correction Joshua
