Hardcoding Username and Password into AuthenticationView
1142
06-26-2018 05:12 AM
KyleSchultz
I have this
    AuthenticationView {
        anchors.fill: parent
        authenticationManager: AuthenticationManager
I would like to declare a username and password for a map service without the need of asking the user for a password.
I tried declaring credentials:
'{"username": "user","password": "pass"}'
but that failed as well...I can't find any documentation on how exactly authenticationManager operates.
Any help would be appreciated.
KyleSchultz
So since no one has answered this question I found a backwards work around for it.
The directory
C:\Users\<username>\Applications\ArcGIS\AppStudio\bin\qml\Esri\ArcGISRuntime\Toolkit
contains files, AuthenticationView.qml and  AuthenticationView20.qml
in both of these files I changed the lines(they are very the same)
 if (Number(challenge.authenticationChallengeType) === 1) {
    // ArcGIS token, HTTP Basic/Digest, IWA
               createView("UserCredentialsView.qml");
            } else if (Number(challenge.authenticationChallengeType) === 2) {
                // OAuth 2
                createView("OAuth2View.qml");
            } else if (Number(challenge.authenticationChallengeType) === 3) {
                // Client Certificate
                createView("ClientCertificateView.qml");
            } else if (Number(challenge.authenticationChallengeType) === 4) {
                // SSL Handshake - Self-signed certificate
                createView("SslHandshakeView.qml");
I changed the first if statement to(making sure to remove createView() or comment it out.)
     if (challenge)
                    challenge.continueWithUsernamePassword('username', 'password');
                //createView("UserCredentialsView.qml");
Now to make sure you project gets built in with it  copy the directory
to the project root of your folder and then call
import "ArcGISRuntime/Toolkit/Dialogs"
within your qml file
and the finally invoke as you would
        authenticationManager: AuthenticationManager // set the authenticationManager property
which will call everything with a hard coded username and password.
This is kind of a backwards way of doing it. If anyone has a cleaner solution I'd much appreciate it.
The documentation for qml and for AuthenticationManager is poor.
GeneVaatveit
Did you ever find a better way of doing this?
It seems AuthenticationView.qml has been updated in Toolkit and is no longer compatible with your solution.  However I did find the right version in the Token Authentication sample.
