Why can't I load a multipoint feature class into a feature dataset in SDE?
3659
6
06-11-2018 12:10 PM
JenniferVanHouter
I am building a terrain dataset and I am trying to run feature class to feature class for a multipoint feature class from a file geodatabase into the feature dataset I created in SDE but I keep getting error 000224: Cannot insert features? The multipoint feature class has just under 4 million points and I was able to load it into a file geodatabase and then successfully run create terrain on my local machine but this error keep popping up when I try to load the data into an SDE database. I double checked and the coordinate systems are the same for the multipoint feature class and the SDE feature dataset.
I am sure there is something I am forgetting to check, does anyone have any ideas? I have attached a screen shot of my tool window and a text file showing the results window errors. I am attempting all this using ArcMap and ArcCatalog 10.3.1.
JakeSkinner
Esri Esteemed Contributor
Hi Jennifer,
Is the Enterprise Geodatabase feature class of type 'multipoint'?
JenniferVanHouter
Yes, I made sure that and the coordinate system matched.
JakeSkinner
Not the coordinate system in this case, but the geometry type.  If you right-click on the feature class in the catalog window > Properties > General tab it will show you the geometry type of the feature class:
JenniferVanHouter
Yes they are both multipoint geometries
JakeSkinner
That is strange, can't say for sure why that error is occurring.  One thing you can do is load the data into a File Geodatabase Feature Class and then either copy/paste or Import the File Geodatabase feature class into your Enterprise Geodatabase.
JenniferVanHouter
Thanks Jake I will try this and post my results.
